low Fuel Light Blinking
I have a 1990 911 Targa (964) and the low fuel light is blinking with a full tank. Now a little over a year ago I replaced the original fuel sender in the tank purchased it at Vertex and it stopped now it has started again, is there some other component that needs to be replaced or do I need to buy a new sender again? Thanks for any help!!!
Old 08-10-2013, 02:39 AM
UnRegistered User
billybek's Avatar
Add fuel?
Sorry that was of no help.... Recheck your terminations/ground?
If nothing else, a free bump...
Bill K.
Old 08-10-2013, 07:41 AM
Member 911 Anonymous
DRACO A5OG's Avatar
+1, check your ground, if that checks out then sorry, buy OEM unit, Switches and Senders are best if PAG, they are so critical components plus PAG warranties them for 2 years.
'85 Carrera Targa
PCA/POC
Old 08-10-2013, 07:49 AM
ROW '78 911 Targa
timmy2's Avatar
Pull the sender and check if the bottom nut and plastic spacer to the outer tube is still in place. Mine fell off and the outer tube was touching the lower contact intermittently doing the same thing. Replaced it with a new sender.
Old 08-10-2013, 08:04 AM
Thanks for all the advise this will be a huge help thank you everyone
Old 08-10-2013, 02:50 PM
