KTL KTL is offline
Schleprock
KTL's Avatar
Remember that the aspect ratio (55, 50, 45 etc.) is a percentage of the width (205, 225, 245, etc. So a 205/55 has a theoretical sidewall thickness of 205mm x .55 = 112.75mm. The 245/45 has 245mm x .45 = 110.25mm Difference of about 2.5mm is pretty small.
However the 245/50 has a 122.5mm sidewall = 10mm gain, more significant
Kevin L
'86 Carrera "Larry"
Old 04-28-2010, 08:18 AM
Steve W's Avatar
Originally Posted by BarryJB View Post
Steve, on the fenders, did you just give them a gentle two-handed heave-ho, or use some more exotic tweaking technique? I'd like to do that on the rears on mine for sure...
I think I just used my hands and pulled them. You could try a pipe leveraged against the tire, but you must back the fender from the inside or risk dinging the sheetmetal.
Old 04-28-2010, 09:26 AM
Uno Dei Molti Porschisti
BarryJB's Avatar
I'm going to try this, better than messing with camber. Your mention of backing jogged memory of an old post about using a baseball bat and a flexible sheet of UHMW polyethylene material as low-friction backing to roll up fender lips... I'm guessing same approach with a somewhat thicker but still flexible sheet would work well to reshape the fender arches. But I need such a tiny amount, I'll try the two-handed heave-ho first though, taking care not to visualize creating a nice sharp vertical crease ;¬)
Thanks!
85 Carrera Coupe, OBD-I 993 3.6 conversion (bottomless list of mods)—425k+ miles. 100k on the 3.6, zero blue smoke, but oh the leaks... two broken 915s But G50 and all the other bits going in early 2024
Consolation & stealth vehicle: 05 Mercedes E55 AMG S211 "No one will suspect the Spa... silver station wagon".
Old 04-28-2010, 01:55 PM
