Street Driving - Brake Piston without dust boot
When swapping out brake pads I removed a badly worn dust boot.
Can I replace the dust boot without removing the caliper? Any tips? What are implications if I drive without replacing the dust boot (street driving). |
Should be able to. There are two kinds of boots. One has a steel ring with the rubber of the boot molded around it. I find these nearly impossible to install even with the caliper in my vice.
The other has a separate split steel ring - install rubber part, slip ring over it to hold in place, all done. I'd not worry about some driveing with a bad dust boot. Happens all the time, as they can fry easily, especially if track driven. Put another way, order boots, but drive in the mean time. |
Member 911 Anonymous
Welcome to the board!
If front they are pretty easy, the rears are another story. It is best to press them on while off but in a pinch go to a hardware store and get a 1/25" PVC coupler and use that with a wood clamps and press it on. May need several attempt to snap it on. The rear's have a barbed ring to fit over the caliper.
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
Spiderman
Just did a brake caliper rebuild myself (on an 87)and I can say that I'd be suprised if you could replace a dust boot without caliper removal. As others say, probably should just put it on a "to do" list for next time you replace pads, add in caliper removal (easy) for new boots. Fronts boots easy, rears require a quick mod to the clipping ring.
Midnight Blue 08 Cayman S, Fun/Track Black 12 VW-GTI, work Mexico Blue 87 Carrera, sold, sad, not enough garage space. |
Thanks for advice.
If I drive without a dust boot for a couple of months in the rainy east coast winter season do I risk killing the piston (excess moisture?) If not, I'll put in on my to do list when swapping out the front pads in the spring. Cheers, Todd |
Spiderman
Probably not but of course no way to know. If your pads were worn, probably less cylinder surface is actually exposed so ? Lots of "what ifs". Since this happens all the time and it usually isn't fatal, I'd risk it. Just don't forget it.
Somatic Negative Optimist
![]() An easy test to see if there is already corrosion/rust on the piston is to push it back, then use the pedal to bring it back out. Caliper pistons move very little during regular driving/braking and they can rust up since ALL brake fluids contain a low amount of moisture. So, moisture from the inside and water/dirt from the outside will do it. ![]() The other items that usually rust up are the bleeder nipples. Put a few drops of penetrating oil on them and crack them lose briefly until a little brake fluid comes out. Don't worry, air will not enter, since gravity works down, not up.
1980 Carrerarized SC with SS 3.2, LSD & Extras. SOLD! 1995 seafoam-green 993 C2, LSD, Sport seats. ![]() Abstract Darwin Ipso Facto: "Life is evolutionary random and has no meaning as evidenced by 7 Billion paranoid talking monkeys with super-inflated egos and matching vanity worshipping illusionary Gods and Saviors ".
| Tags |
| brakes , dust boot |
