checking valve adj?
If you adjusted your valves a month ago and wanted to check oon them do you think you could get away with not replacing the gasket/lock nuts?
If you are not changing the oil do you just have to drain it out of the sump to keep it from running out the valve covers?
Rick
88 Cab
Old 04-30-2010, 08:47 AM
Somatic Negative Optimist
Gunter's Avatar
rick,
Yes, you can.
I've been re-using the same gaskets, Nyloks and washers for years.
It's critical to have the mating surfaces very clean.
Simply smear grease on both sides of the gaskets and they won't stick.
We've been doing this in industrial applications for a long time; it works!
Some people just lift one side to tilt the car but I recommend that you drain the 2-3 liters out of the sump.
Re-use the Nylok nuts and Alu crush washers.
You can also check the covers for straight by using a sheet of fine sand paper on glass and gently slide the covers over the sand paper. That rubs off the high-spots.
1980 Carrerarized SC with SS 3.2, LSD & Extras. SOLD!
1995 seafoam-green 993 C2, LSD, Sport seats.
Abstract Darwin Ipso Facto: "Life is evolutionary random and has no meaning as evidenced by 7 Billion paranoid talking monkeys with super-inflated egos and matching vanity worshipping illusionary Gods and Saviors ".
Old 04-30-2010, 09:19 AM
I'd buy at least a new set of lower gaskets as a back up before proceeding.
Old 04-30-2010, 10:59 AM
muck-raker
kidrock's Avatar
I've had excellent results with the fiber gaskets, but recently decided to go with the reusable silicone gaskets. They are also excellent...no leaks when installed correctly. Why take the chance?
STONE
'88 Cabriolet, using EP Slick 20w50 partial synthetic Snake Oil...just as Rommel intended.
Deny Everything; Admit Nothing; and Always Make Counter-accusations
Old 04-30-2010, 11:04 AM
