Certified Pre-Owned
BGCarrera32's Avatar
Thumbs up Speedy tip for removal of frozen ball joint nuts
Hi-
So I am currently replacing the ball joints as part of a suspension overhall and I ran into the old frozen castellated nut problem. One of the ball joint nuts came loose pretty easy with a little heat and a big breaker bar, but the other one just wasn't gonna move. Here's a simple tip that I bet is even easier than the carbide cutter in the dremel trick. I got the nut off in less than 5 minutes- no sweat. This will destroy the nut and the ball joint, but if you are replacing the parts anyway than it doesn't matter.
You need a cordless drill and a few bits. Start with about a 3/32" bit and drill a hole right on the threads between the castellated nut and the ball joint. Start in one of the grooves where the tooth of the ball joint tool would sit. Drill down to the A-arm. Use a piece of masking tape wrapped around the bit as a depth gauge so you don't drill too far. Increase the bits successively in size until you breech the o.d. of the nut. Once you have breeched the o.d. of the nut, stick a big screwdriver in the slot you formed and give it a pop- this should do the trick. If you are careful, you won't even make a mark on the A-arm. Piece of cake. If drilling is a little tough, add some WD40 or light oil to the bit to act as a cutting oil.
Good luck!
BG
'84 Carrera Coupe
Old 12-28-2002, 09:23 PM
Author of "101 Projects"
Wayne 962's Avatar
Hmm, I have a better suggestion - simply cut the nut in half with a carbon-reinforced cut-off tool and a Dremmel. Mine came off in about 1 minute. Drilling will work too, but you might go through a bunch of drill bits (they are not really designed to drill like this).
-Wayne
Old 12-28-2002, 11:51 PM
Senior Member
BG and Wayne,
I assume that you guys have the special socket that fits the nut? Where can I get one to reinstall the ball joints?
Noticed this socket on the website but it does not look like it has the tits that go in the nut.
http://www.pelicanparts.com/catalog/shopcart/DWKS/POR_DWKS_toolsL_main.htm
Thx,
Joe
Old 12-29-2002, 09:36 AM
Certified Pre-Owned
Obviously the cutoff wheel will work, but I didn't have one on hand. The drilling did no damage to the bits and was so easy I thought I'd post.
Wayne, your book says the final nut torque is 33.1 ft. lbs (ball joint to a-arm). The detail sheet that came with my new Sway-Away bars says its 108 ft. lbs. I am assuming the lower value is correct. Care to confirm?
Check for the ball joint tool here : (look under ball join tools)
http://www.pelicanparts.com/catalog/shopcart/911M/por_911M_suspen_main.htm
'84 Carrera Coupe
Old 12-29-2002, 10:39 AM
KTL KTL is offline
Schleprock
KTL's Avatar
I think that 33 ft-lb value you have is for the castle nut on the tie rod at the steering knuckle. That's what's stated in the 84-87 spec. book.
The torque spec. for the slotted nut on the ball joint is 250 Nm = 184 ft-lb
Kevin L
'86 Carrera "Larry"
Old 12-29-2002, 02:54 PM
docrodg's Avatar
+1 on the dremel. Wonderful tool for the garage. Does just about everything, like the old commercial they had, except hammer a nail (well, you could hammer a nail but it would kill the tool swinging the housing against the nail). Get the flex shaft version and you can get into tight spaces.
Pickle forks are a PITA tho. On most cars the control arm is hefty enough that you can smack it with a big hammer one good blow while prying down on the joint, popping the ball joint out from the shock vibration of the smack. Have not done this on a P-car, never had to replace the joint. Be warned, some cars this will not work on as the form of the arm is wrong. In that case you can get a pickle fork that fits in an air hammer Keep the force low, it won't take much.
1968 911S "Leona"
Air goes in and out, blood goes round and round, any variation on this is a bad thing.
Old 05-08-2010, 04:09 AM
Just removed a pair if ball joints on my '80SC last week. Pondered for a while, got the 18" pipe wrench, a little grunting, and Voila!, they spun right off!
'80SC Widebody 3.6 transplant Anthracite "The Rocket"
Long gone but still miss them all:
'77 911 Targa, '72 BMW 3.0CS Coupe(finest car I ever had!)
'71 911T Coupe White, '70 911T Coupe Blue
'68 911 Coupe Orange, '68 911L Soft Window Targa
Old 05-08-2010, 05:36 AM
Home of the Whopper
Hmm, I have never had a problem with the ball joint tool, and I have done dozens on early cars. I use a ball joint tool on an impact and use a jack to apply pressure. make sure everything is square, zap the gun a few times and they usually spin right off. Sometimes I hit with WD and heat a few times, but I have always been able to get them off without cutting.
“The wave is not the water. The water merely told us about the wave moving by” – Buckminster Fuller
Old 05-08-2010, 07:48 AM
wdfifteen's Avatar
I used an air hammer. Ground an old punch tool down to the shape needed to fit the ears on the nut. Took about a two second burst to get it spinning.
Old 05-08-2010, 09:25 AM
Tim
Send a message via MSN to tvanbroekhoven
Dremel! No contest (I haven't got a air hammer so couldn't compare)
Old 05-08-2010, 09:50 AM
Joe,
The correct tool is PEL-TOL-P210. The teeth are on the inside.
Scott Wilburn
1988 911 Carrera 3.4 L
1998 M3
1984 308 QV
Old 05-09-2010, 07:34 AM
Yup. I used a 24" pipe wrench and an old galavanized fence post. The balljoint socket was not even damaged, so I re-used it.
Old 05-09-2010, 12:29 PM
