94 carrera turn signal issues (too fast)
i have a 94 carrera with turn signal issues. they are flashing too fast. all bulbs are good. they work fine when i use the hazards. any ideas?
Old 05-14-2010, 12:06 PM
dshepp806's Avatar
Wrong forum,..BUT,..either you've a ground issue or the wrong bulbs.
Best,
Doyle
Recording Engineer, Administrator and Entrepeneur
Designer of Fine Studios, Tube Amplifier Guru
1989 Porsche 911 Carrera Coupe
25th Anniversary Special Edition
Middle Georgia
Old 05-14-2010, 01:54 PM
DW SD's Avatar
might not have an OEM relay.
I have a generic german one (probably made in China) that flashes too fast. Not to denigrate Chinese or their products.
Doug
1971 RSR - interpretation
Old 05-14-2010, 02:19 PM
DW SD's Avatar
Best,
Doyle
Doyle,
Just curious, what year 911s are welcome here?
Doug
Old 05-14-2010, 02:20 PM
80-911SC's Avatar
there is a 964 and 993 forum
you would get the same response to a 914 question, and god forbid you ask a water cooled question ......... unless you have retrofitted it into an earlier car or done the v-8 conversion, although the last may get you ribbed for a minute
Old 05-14-2010, 06:23 PM
