Dave Kost's Avatar
1979 911E spark plugs?
What is the recommended plug for a 911E with MFI?
Thanks,
Dave K
Old 03-17-2011, 09:37 AM
Dave Kost's Avatar
Mistake.....
1970 911 e
Dave K
Old 03-17-2011, 09:39 AM
Max Sluiter
Flieger's Avatar
I can't comment on the heat range, but use the normal Copper Bosch ones with a single electrode.
You generally want the coldest plug that does not foul, which might need to be pretty hot with MFI if you drive mostly in the city.
Old 03-17-2011, 11:01 AM
Friend of Warren
NGK BPR6ES If you live in an extremely hot area of the U.S. you can go one cooler which would be a BPR7ES
Kurt V
Old 03-17-2011, 11:22 AM
cmcfaul's Avatar
Send a message via AIM to cmcfaul Send a message via Yahoo to cmcfaul Send a message via Skype™ to cmcfaul
I personally like the non copper plugs (platinum, iridium). Found my car runs and idles better.
MFI typically runs rich and a bigger spark helps.
Chris
73 911 E
Old 03-17-2011, 12:03 PM
