What have I done? Rear wheel bearing debacle
I had the whole thing back together when I realized I forgot to put the wheel bearing cover back on the control arm. I tried to pound out the hub from the bearing with the 27mm socket like I had originally, but this time the whole bearing/hub assembly came out and now I can't separate them. Also, the bearing didn't look like this when I installed it, do I need to replace it?
Gone
92 C2
82 Euro SC race car
993 C4S 3.8
84 Euro Carrera
Old 05-20-2010, 07:38 PM
yup get a new one and start over. i did the same thing.
Jason
81 SC
97 328is
87 Jeep Comanche (RIP)
Old 05-20-2010, 09:44 PM
Senior Advisor
James Brown's Avatar
Just like removing the old one, you only get one shot at it.
08 Cayenne Turbo
Old 05-20-2010, 09:59 PM
I took a little different route but had the same result. When I went to the mechanic to get another bearing he laughed and said, "we have all done it just move on." New one seemed to go in better.
Kevin
'79 Coupe
Old 05-20-2010, 10:18 PM
OK no big deal, get a new bearing, but how do I separate the trashed bearing and hub? Machine shop? I tried my 3 jaw puller, but it doesn't fit well enough to pull it. Thanks.
Gone
92 C2
82 Euro SC race car
993 C4S 3.8
84 Euro Carrera
Old 05-21-2010, 03:53 AM
tobluforu's Avatar
I learned my lesson as well, bring it to a shop and have them do it in minutes.
Old 05-21-2010, 04:15 AM
kwikt 911's Avatar
Yep, I did the same screw up. The next time I replaced it, I hung the backing plate on the trailing arm as a reminder to reinstall.
Old 05-21-2010, 05:25 AM
Home of the Whopper
Did you freeze the bearing before installation? Makes it go in easier.
“The wave is not the water. The water merely told us about the wave moving by” – Buckminster Fuller
Old 05-21-2010, 07:09 AM
When I went thorugh this, I took my Dremel tool with the Fibre Cut off wheel and sliced off the outter race then then cut the inner race (Carefully) until almost through and hit the groove with a Chisel and it split and then was off. Now I would use the cut off wheel on the cheap Harbor Freight 4 inch grinder and do the same thing
Made History at Daytona and Still one Fast Old Man! 1982 Porsche 911 SC & 2017 Honda Si
Old 05-21-2010, 07:22 AM
Took it to the shop, and yes, I did freeze it. I have the puller Pelican sells, and it made the initial removal and install a breeze....until I forgot to reinstall that damn plate. Oh well.
Gone
92 C2
82 Euro SC race car
993 C4S 3.8
84 Euro Carrera
Old 05-21-2010, 08:17 AM
there are two types of bearings out there with the same dimensions.
1 - the seal slips on the outside race
2 - the seal slips on the inside race
On the original seals on the inside race. I think this is better because it keeps the slip surface further away form debris.
Don't feel bad, I had to buy an extra bearing when I forgot to put the sheet metal on first.
I froze the bearing and heated the arm, it went right in.
There is a long thread on here about this.
Old 05-21-2010, 08:50 AM
Author of "101 Projects"
Wayne 962's Avatar
This was done on a 996 Turbo, but almost all wheel bearings are very similar. I spent a long time making this article very complete, because I know there were no good articles on wheel bearing replacements out there before.
http://www.pelicanparts.com/techarticles/Boxster_Tech/40-TRANS-Wheel_Bearings/40-TRANS-Wheel_Bearings.htm
-Wayne
Old 05-21-2010, 01:35 PM
Wayne, did I "Again" miss something? In one Pic we aee the inner race of the bearing still on the Hub and in the next frame they are pressing the NEW Bearing into the swingarm. Did I miss how they got the inner race off of the hub?
Old 05-21-2010, 01:49 PM
Walt Fricke's Avatar
Well, it is too late for you to do this, but here is a trick if you forget to install the bearing retainer plate/cover before you put the flange into your new rear axle bearing.
Cut the cover in half, and install the halves. There is just enough room to get short 8mm bolts in there between the flange and the demi-plate. I can't recall (this painful episode was 15 or so years ago) whether I had to find shorter bolts, or if the stockers worked. An open end 13mm wrench worked fine once they were started.
Haven't had a problem with it since. Necessity is the mother of invention. Also, this is a track only car, so no parking brake assembly. Might change things.
But I have a replacement retainer on the shelf against the day that bearing needs replacement.
Old 05-21-2010, 10:29 PM
Be mindful of the torque needed on the axle nut or you'll be doing this again in a few thousand miles. I had to buy a special socket and wrench to get the required amount of torque.
Old 05-22-2010, 12:24 PM
911mnypt's Avatar
What is the torque needed on the axle nut?
P-car no more
2000 F250 Powerstroke Crew cab "Growler"
2007 Honda Odyssey "The Bus"
2006 BMW 330i Manual 6 speed "The Sled"
1987 Mercedes 560SL
Old 05-22-2010, 12:44 PM
I think it's 340 ft lbs. All I know is that your typical 1/2" wrench will twist in half, and therefore you need a good 3/4" drive socket and wrench. Look into a Wright Tools socket, and an Ace Hardware wrench, or buy the socket and lease the wrench. Then a 4' long steel tube or box iron beam goes over the wrench, and you stand on it about 3' from the centrline.
Old 05-22-2010, 01:25 PM
