2.2 distributor application question
Hi
I have a 2.2T , and was told its distributor needs to be replaced by my mechanic. I have found a bosch 2.2 s unit and wondered if or how it would work with my engine. All I know is that its limiter will be higher. as always, thanks for any help!
1970 911 t (sold) 1985 MR2 (sold) 2011 GT 5.0 2007 CRV |
Reg,
I hope you haven't found the same "S". I am wondering the same thing, can an "S" distributor be recurved to T specs? If so approximate cost. Anyone you would recommend for the task in Northern California? Thanks,,
Craig Dinger '02 Sampson Titanium, Campagnolo 20 speed roadbike, daily commuter, 3,700 miles and counting '71 911 T Targa for fun '89 BMW 325i sedan wife' ride '83 BMW 533i White/Cardinal red leather, Wet weather commuter '89 BMW 535i auto to 5 speed conversion in progress '98 Ford F-150 weekend hauler |
maybe we can swap 1600 toyota parts too
![]() I have 1st dibs on it, at least requested them!
Reg,
I'd be happy to swap my tired carbureted engine for a peppier fuel injected version ![]() We must have found different dist, I am in the process of purchasing one. Good luck with yours. I emailed Steve Weiner re-curving the 2.2 "S" dist to 2.2 "T" spec, he felt the 2.2 "S" dist would work fine if set to 35 degrees total advance. Gets expensive to re-curve so I sure hope he is right. I guess if you want to wait and use me for a guinea pig I can let you know how the dist works for me. If you read my recent post re: the clutch release it may be a little while before the car is up and going again. I am in the process of degreasing the tranny right now, then onto the tranny side of the motor, then clean up the engine compartment a little, then finally put everything back together.
Senior Member
Hello
Sure you can recurve most distributors to any curve you want. Its just some wights and springs. Not a miracle. Grüsse |
Thanks guys.
The one I am looking at is in CA.... I bet its the same one. ![]() Yes, my 1st yr MR2 is a great little car. No T Tops ![]() The kikker for me is the exchange rate. This unit is 200US$ , and by the time I get it I am looking at $400 Canadian. FTR. Wayne's book is excellent, but it cost $70 of my dollars up here!!! An expensive Christmas gift! Thanks Mom! ![]()
Reg,
The dist I found is $100, $105 with shipping, and yes I bought it. Part number is 0231-159-007. Seems the exchange rate sucks for you. Try posting a wanted ad. I did and that is how I found the dist. I had someone write me about a 69 "T" dist but they haven't gotten back to me after I asked for a part number. I also had someone offer me a 70/71 "T" dist that turned out to be a 73 "T" dist based on part number 0231-169-008 and the 73's had a different size housing that fits into the engine case. see Warren's and John Walker's post here Very important to check part numbers in my opinion since I had many people tell me they had a dist for me that turned out to be something other than what it was represented as. I assume these are innocent mistakes based on fading memories, etc, but I don't want to be a party to the mistakes. I bought the "S" dist since it was a good price and I didn't want to miss the opportunity while waiting to here back about the 69 "T" dist. If/when I here back about the 69 "T" dist I'll send you the info. Best of luck on your dist search.
Thread Tools | |
Rate This Thread | |
