H1 Rebuild Help
I have found a place to get te flexible shafts used in the H1 headlight assemblies. Go to this website and scroll down to the part number SHW 152When you get these shafts have both ends drilled and tapped to whatever thread you would like to use. I could not find the metric threaded oval headed phillips so I went with 8-32 stainless steel oval heads from Fastenal. Hope this helps someone
Drive Shafts
Rick T |
AutoBahned
1/4" Flex Drive Shaft
... thx for posting that - it will help many people |
Happiest when Tinkering
+1 I will be in need soon.
" Porsche there is no substitute" I always liked that saying. Air cooled is the only way to go! 76 911 C.R.A.P. Gruppe #2 BIG time TURBO C.R.A.P. Bitz EFI/EDIS Now MegaSquirt 3 76 Blazer also restored by me |
