'73 911 T Targa
How to keep sidewall carpet in place?
I'm looking for ways to keep the carpet in place on the sidewalls of the footwells. As you can see in the picture, glue didn't work very well for the previous owner. I was thinking about sheet metal screws with trim washers - is that taboo?
911SC Tinkerer
Maybe the glue is just old? You could try a new layer of stickier glue like 3M Super 77 or 90 after stripping the old glue off.
-Steve
-'83 911SC Coupe SSIs, Dansk GT3, EFI ITB, Instagram: @ Zinnmetallic_sc |
I wouldn't drill any holes there. I use Wurth glue, just make sure you apply to both sides and wait at least 15 minutes before gluing.
The heater tube makes it hard for it to seat well but it should hold.
1973 911S (since new) RS MFI specs 1991 C2 Turbo |
+1 on what has been said, don't drill holes in your car please!
Use grease and wax remover to remove the old glue, and then use something that good.
Classic 1969 911T |
Clean as much of the old glue off as possible. I have had new glue reactivate the old and then nothing will stick.
1982 911 Targa, 3.0L ROW with Webers |
Senior Advisor
3M 77 use it all over the car to shore up gravity-induced problems
08 Cayenne Turbo |
I think i punched a little hole in the carpet and used a zip tie loosely onto the big black wire loom for that spot
82 SC , 72 914 |
'73 911 T Targa
By Wurth Glue, do you mean Wurth Weatherstrip adhesive, or something else? |
use this. follow the directions and you will be a very happy person (after you have thoroughly cleaned all areas).
http://www.amazon.com/3M-74-Adhesive-Orange-Aerosol/dp/B0002BBV28
- He gave his father "the talk" - Once while sailing around the world he found a shortcut - He taught a german shepard how to bark in spanish He is.... nineball. I don't always drive sports cars, but when I do I drive a 1983 911SC Targa. Stay fast my friends. |
