Broken H4 Bulb Connector
The connection pins in the H4 headlight connector are broken and will not make contact with the halogen bulb pins. I need to find a new connector with good pins that I can splice into the harness. Alternately, If I could find replacement pins, I could cut out the old ones and replace. Does anyone have any ideas where I might find the part or parts I need.
Old 05-22-2010, 05:22 PM
Send a message via AIM to Oldporsche
Cool
For temporary relief, female insulated blade terminals can be crimped on the appropriate wires. You might start checking foreign salvage yards.
Old 05-22-2010, 07:05 PM
80-911SC's Avatar
you can get an H4 connector at any auto parts store, or get the ceramic ones from an on line auto electric supplier
danial stern lighting has the connectors
Old 05-22-2010, 09:14 PM
Thanks for the quick replies. I'll try the local auto stores first. If nothing, I guess it will be the online route.
Old 05-23-2010, 03:30 AM
Found the connector at Autozone. Replaced it and a fuse. Back in order. Thanks for the tip on locating a connector.
Old 05-23-2010, 08:54 AM
