re curving dizzy?
Hi Guys,
I'm pretty new at this but is there a DIY on recurving your distributor? I heard you can recurve a 3.0 by 28 degrees and was wondering if someone can advise me the right direction to someone who can (to send out). Also is there any threads to understand more about this? Been trying to find one in the search forums but having a hard time. Many thanks.
Old 05-25-2010, 11:11 AM
brads911sc's Avatar
Send it to Barry Hershon in Detroit. He is hands down the best on these. He will also rebuild it, which it will need unless its been recently done. The latest PMO Advertisement in Panorama and Excellence has his information.
83 SC Targa -- 3.2SS, GT2-108 Dougherty Cams, 9.5:1 JE Pistons, Supertec Studs, PMO ITB's, MS2 EFI, SSI's, Recurved Dizzy, MSD, Backdated Dansk Sport Stainless 2 in 1 out, Elephant Polybronze, Turbo Tie Rods, Bilstein HD's, Hollow 21-27 TBs, Optima Redtop 34R, Griffiths-ZIMS AC, Seine Shifter, Elephant Racing Oil Cooling.
Old 05-25-2010, 11:30 AM
Originally Posted by jinos View Post
Hi Guys,
This is not a DIY project.
One needs a distributor machine to measure and set the advance system up. Further, if your distributor bushings are worn, Barry can install new ones as well.
Call Barry at (313) 532-5350 and tell him I sent you.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 05-25-2010, 12:15 PM
brads911sc's Avatar
Thanks Steve!
Old 05-25-2010, 12:28 PM
Halm's Avatar
Steve, does Barry also convert distributors to mechanical advance?
'17 Cayenne
Old 05-25-2010, 12:49 PM
Thanks guys! This is the first time I'm doing something this technical. I've only done: brakes, suspension, plugs, oil changes, fluids, accumulator, frquency valve, etc. I'm not a handy man but I can do the basics. So since this is the first time doing this I was wondering if someone help me with these few questions.
1) I'm running a 3.0 from an 80 in my 74 911. all stock except a cat bypass and muffler. Since it has CIS still I was advised to recurve only 28 degrees. Does that make sense? Something about CIS running too lean for an agressive curve.
2) I don't plan on getting carbs so does 28 degrees seem right?
3) I'll be sending out my distributor to get it done but the cap/rotor are all new. After getting it recurved how do I reinstall it? Sorry for the stupid questions but want to make sure I do this right. What is the step by step prodecure? If anyone has a thread for this where I can review?
4) All your advice is greatly appreciated.
Old 05-25-2010, 01:45 PM
brads911sc's Avatar
Yes.
He did mine.
Old 05-25-2010, 01:55 PM
rfuerst911sc's Avatar
Jerry Woods in CA. did one of mine. Barry did the other. Be prepared for sticker shock as each charged aprox. $500.00 for full rebuild/recurve/etc. for my 3.0's with carbs. I am happy with the performance of both.
Old 05-25-2010, 02:33 PM
brads911sc's Avatar
Mine was $550 with Barry... But came back like brand new. If it lasts 100k miles... that about another 25 years... not bad when put like that...
Old 05-25-2010, 02:43 PM
Senior Advisor
James Brown's Avatar
For less than half that price you can convert to an electronic distributor-less system and program your own vacuum "curve". and enter the 20th century! (Ok, I still have carbs). All you need is a laptop.
08 Cayenne Turbo
Old 05-25-2010, 03:30 PM
How do you do that?
Old 05-25-2010, 03:35 PM
Senior Advisor
Look up EDIS on here and on the web
08 Cayenne Turbo
Old 05-25-2010, 04:21 PM
oneblueyedog's Avatar
Barry Herscon also did mine 313 532 5350. Running great 50k mi so far.
78SC coupe, Silver Metallic
Old 05-25-2010, 06:03 PM
JMHO, but carbureted cars using distributor-triggered MSD's run FAR better than the ubiquitous EDIS systems do.
Send that thing to Barry and it will come back like new. Bee sure to tell him your engine specs, what octane fuel you use, and it will drive out much better than stock.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
Old 05-25-2010, 06:12 PM
Senior Advisor
FAR better? with mechanical advance and like an AL ignition box, and good wires.
08 Cayenne Turbo
Old 05-25-2010, 07:07 PM
