Points!!!!!!!!!!!!!!!!!
Okay Fellas, I know their have been numerous threads on the issue of points; however, I never did get a feeling or concensus on what to use as a reliable, sound replacement.
I have a 1973.5T and like many of you have had headaches over the damn points, wearing fiber blocks, bouncing tach, backfiring and the usual anxiety of waiting for the next problem.
I am now exploring the newer system(s) available to replace these ancient points and have read about and priced out many options.
Having read about problems with the "ignitor" and the failure and installation concerns (where those wires go!), I question reliability and real ease of installation.
The Allison Crane system looks to be the best to me, but I have not heard of many installations on this board.
I do not want to drag this subject thru the mud, but for those who have installed replacement systems can I get a feel for what has and has not been reliable for you so I can move on greater reliability of this system.
My glove box is becomming overwhelmed with extra points, feeler gauge, magnetic screwdrivers and lobe grease. I think I had enough!
Many thanks
Bob
73.5 T w/bosch dist.
Old 12-20-2001, 08:24 AM
tobluforu's Avatar
Sorry, can't help. But, i do have th crane fireball coil on my 72 and it was easy to hook up and works great. Get the crane and tell us how it works so maybe we can do the same.
Old 12-20-2001, 02:55 PM
I have a Newtronic's optical unit in my car and can't speak highly enough of it. It was professionally installed about 4 years ago by the PO and in the 3 years I have owned the car it has been great. I can't remember my car ever backfiring, starting is always reliable and servicing costs down due to the fact that the timing is now set and forget. I have the original installation instructions and it looks remarkably simple.
Cheers
Paul
1969 Porsche 911T 3.2 (Matching # engine safely in storage)
2021 AMG C43
2020 BMW X4
1979 Californian Moke
Old 12-20-2001, 03:10 PM
ffilips's Avatar
Send a message via ICQ to ffilips
Lightbulb
I'll be installing an Ignitor unit this weekend. I can let you know just how easy it really is, as for reliability can't be any worse than points.
69 911t
86 951
Old 12-20-2001, 03:16 PM
boyo's Avatar
Yeah, except points cost $6 and the Ignitor costs $60... Better be 10 times as good!
-Boyo
Old 12-20-2001, 03:46 PM
I have points in my car - they were fairly easy to adjust, have maintained their adjustment, and have no running problems. I'm not trying to brag, but I'm starting to wonder - am I just lucky? Does anyone else still use his original ignition system without problems?
1972 911T Coupe
Old 12-20-2001, 06:31 PM
Cool
No problems in a 2.7 dizzy w/ 130,000 mi
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 12-20-2001, 06:34 PM
points vs ignitor
I had an ignitor and it is up in the loft now. I do not remember the exact thing that went wrong, but it got too weird for me to stay with.
Replaced it with new points 3 years ago. Same ones there now. I just periodically check and reset the gap. Has not moved much. I also set the timing to TDC at idle and go down the road. The car gets run in TT events, on the street and the like. As the points are not pitting, I have no intent to change them soon.
___________________
Steve- 62 356 S90 Sunroof-sold 11/16
73 911 No longer Targa-3.2L Running GT4
88 Carrera G50 sold 2019
2015 Cayman GTS
Old 12-20-2001, 06:37 PM
Thanks guys.....
Critical decison time is coming...lots of options.
Regards
Bob
Old 12-21-2001, 06:52 AM
I installed a Crane/Allison XR700 in my Bosch distributor 4 years ago and have not had to open/maintain it since nor adjust ignition timing. Indirectly, I'm also saving wear and tear for the next generation of preservationists as the cam lobes are now untouched by points. :-) Am now planning to install a HI-6S box to augment the breakerless setup.
Sherwood Lee
http://members.rennlist.org/911pcars
Old 12-21-2001, 12:59 PM
jkeyzer's Avatar
I installed a Pertronix Ignitor model 1863 (early style distributor) in my 72 last night and drove it 50 miles today. It works great!
I would highly recommend it as a replacement for stock points based on my experience thus far. The cam lobes on my dizzy were somewhat worn and this lets me basically forget about all those problems.
The installation was effortless with my MSD. Points out, ignitor in, make sure it's not rubbing anywhere, red wire to switched +12V (engine fuse block middle fuse), black wire to male spade to existing points wiring (MSD points pickup and tach). Set timing. Took me less than an hour and I even took the distributor out to give me more room to work.
Tach works great, no jumping at idle, throttle response is nice and strong from idle to > 5k.
I am using a rev limiting rotor and apparently it fits. I'll check it soon to make sure there isn't any rubbing of the rotor on the cap where it shouldn't be.
If I did a better job of hiding the wiring, you'd never know it was there.
Jeff Keyzer
72 914 w/2056 built by Mark DeBernardi @ Original Customs
Megasquirt with MSII upgrade
Old 12-22-2001, 01:33 AM
