newbie question. about upgrade engine
hi every one . my car is 77 911. i try to built my carand also to do wild body covversion, now it is just a rollin shell, but i know my car original come with 2.7 l engine with the 915 trans. what is the best option to upgrade the engine , 3.2 or 3.6 , is ok to fit in and turbo engine ? and also can anyone tell me the parts list . thanx
Old 05-30-2010, 12:01 AM
Senior Advisor
James Brown's Avatar
Sure, parts list: 3.0-$$$, 3.2-$$$$, 3.6-$$$$$$$, turbo-$$$$$$$$$ Now, what do you want the car to do? Street, track, show, daily driver? How deep are your pockets? Looks like a little more tweeking to do on that tub.
08 Cayenne Turbo
Old 05-30-2010, 01:35 AM
ok let say if i want to put 3.6 , does need to do any modification to the chassis ? the car will be use on street .
Old 05-30-2010, 02:01 AM
Senior Advisor
All (most) 911 flat 6 engines will fit. Some transmissions (g50) won't without big mods. Staying with the 915 is a good idea. Good bang for the buck is going with the 3.2 but the engine is electronic so you must add the wiring harness, not to bad. Other than that, just go for it!! (paint it later after you get it sorted out)
The 3.6 will need a trans. adapter to fit the 915. There are kits out there that have everything you need to do this, well most everything. Do a search for 3.6 swap.
08 Cayenne Turbo
Old 05-30-2010, 02:31 AM
thanx for ur reply ^^
Old 05-30-2010, 02:38 AM
NewfieMZ3's Avatar
I recommend the 3.2, nicely sorted, I think it is the most economical and sensible application for that car................but then again most of us here are not sensible, just by virtue of being here......lol. If you want to push the limit do the 3.6, but as noted above, what is your intention for the car?
1984 911 Coupe
2007 Z4 M Coupe
2008 Cayman S
2004 M3-Alpine White(sold)
2002 M Roadster (sold)
Old 05-30-2010, 03:22 AM
