85 Carrera Fuel Line Question
Hi Everyone,
Fairly new to Porsche ownership (I've waited 30 years to finally purchase my "dream car"). While poking around in the engine bay, I noticed this tear in what appears to be a fuel line. It's part rubber and part hard line and goes into the back of the Mass air flow sensor. Is this part available? I couldn't seem to find that exact part on PP. ![]()
6 cylinder symphony
It is available.
P/N - 93011032803 It's $134. Mine was busted too. Just changed it, along with most of the hoses on top of the engine. Some people have just put electrical tape over that. I didn't want to do that. Good Luck. Ken
'84 3.2 Targa '89 964 Coupe "What do you mean NEXT project?" - my wife |
Not to nit pick but the item it goes to is the air flow meter.
1974 sahara beige 911 targa 1982 chiffon 911sc 1985 prussian blue metallic carrera |
Certified Pre-Owned
That is an air line on the intake system. I would smear some black RTV on it and call it a day. Not a fuel line...
'84 Carrera Coupe |
Brake booster vacuum isn't it? Ken
Ken in Greer, SC 88 Carrera Coupe 98 C2S Coupe |
Throw it on the ground!
No need to replace this $139 part when it can be repaired using a $3 roll of self fusing silicon tape from Ace hardware:
Repair vs Replacement options for this part?
Mark 1987 911 Coupe Granite Green Metallic My Cousin's Wife's Sister's Husband is a Lawyer. |
To prevent the new rubber from cracking again, support the venturi tube so the weight of it doesn't not bend or stress the rubber.
I have inserted 2 different size hoses in to one another, doped them for a seal and clamped them..It works.
Bruce |
Thanks Guys!
Takes a load off my mind to know that it's not a fuel line, but a vacuum line. Several options to choose for repair. Thanks for all the replys. |
