grahamkissack's Avatar
Thanks for the pipe wrench recommendation to remove ball joint nut!
Someone on the forum suggested I try a big pipe wrench to remove the bottom nut on the ball joint rather than an air hammer or dremmel. I was nervous because there's only 1/8" of material to grab down there. But I tried it anyway by securely attaching the wrench then using a jack to lightly hold it in place. The nut came off easily with a 2 foot breaker bar on the wrench no problem at all! Best part is both nuts are perfect after the removal...no damage at all.
Thanks for the tip.
"Penelope" 1980 SC Targa in Grand Prix White
Old 06-02-2010, 05:42 PM
Good job, I knew it would work for you if you gave it the old college try!
'80SC Widebody 3.6 transplant Anthracite "The Rocket"
Long gone but still miss them all:
'77 911 Targa, '72 BMW 3.0CS Coupe(finest car I ever had!)
'71 911T Coupe White, '70 911T Coupe Blue
'68 911 Coupe Orange, '68 911L Soft Window Targa
Old 06-02-2010, 05:56 PM
That was me, you're welcome....pass that tip on.
Old 06-02-2010, 05:57 PM
That was my post originally and after great response I also tried the pipe wrench.
2 minutes of gentle prying! Thanks much!
Old 06-02-2010, 05:58 PM
Thanks to everyone! Power of knowledge is amazing and this forum makes that transfer happen.
Old 06-02-2010, 09:28 PM
