dozer's Avatar
Factory manuals- 1983 930 / 1978 SC 14-pin conector
Im putting a 1983 (Euro) 930 engine into a 1978 (Euro) 911 SC.
Im trying to sort out the Eletric connections and need some help.
Need to know the color of the wires in the 14 pin connector (and what they do)
I don't have the factory manuals, so if anyone out there do have them or know witch plug goes together, and have the time to help me out, that would be grate :-)
Dozer is online now Report Post Edit/Delete Message
"It gets a little bit louder above 5,000 RPM so you can't hear the passenger scream"
Porsche 911 Turbo
Old 05-30-2010, 08:45 PM
avt007's Avatar
Check this thread- 2.7L to 3.0L Engine Conversion / Swap
It has the wiring I figured out from an 80SC engine 14 pin plug.
Rob
76 widebody project
86 Carrera Coupe
01 BMW X5
98 Jaguar XJ8
Old 05-30-2010, 08:55 PM
dozer's Avatar
Thnx avt007.
Found this...
So if annyon can help with the engine connector (1983 930), that would be grate :-)
Porsche 911 Turbo
Old 05-31-2010, 01:22 PM
dozer's Avatar
Bump...
Still need info on the 14 pin connector coming from engine- Euro 930 1984
Porsche 911 Turbo
Old 06-02-2010, 04:55 AM
Platinum Member
dad911's Avatar
Not that many wires, I would pop the cover and trace them/match up the colors......
Old 06-02-2010, 05:31 AM
