Jack
Heater Backdate Problem - Advice needed
Howdy
I am in the middle of doing a heater backdate on my 3.2. The problem I am having is that the new shroud piece (purchased from our host) doesn't seem to fit very well. I can somewhat align the holes, but it seems off by 1/4 inch or so, especially in the back. I don't see this making anywhere close to a tight fit... Any ideas? Thanks in advance Jack
85 Carrera Cab |
Jack
well, since I had to massage it with a hammer for the disti to fit, I figured what the heck, lets form it. Never thought I would be taking a hammer to a porsche part.
Seems to work now... -Jack
85 Carrera Cab |
At the track = great day
I did exactly the same thing. It doesn't fit around the dizzy very well. But it wasn't anything a mallet couldn't fix.
Lane 2011 Volkswagen Jetta SportWagen TDI Looking for another sports car.. |
grateful user
Hammer is normal procedure on these.
fully disassembled, blasted, customized and restored 75 targa with factory hard top, 993 style turbo ft fenders, steel flares, C2 bumpers and rockers, 82 3.0 sc 9.5/1 engine with PMS flywheel, 964 cams, flowed heads, ssi's short geared 915 w/lsd, polybronze, bilstein,working lambda, modified and highly tuned cis, tensioners, pop valve, backdated exhaust and heater, 2300 lbs. no bolt left untouched. 1970 911E. Nice car but needs a re-do. |
What engine fan shroud do you talk about ???
The right or left one ???
LIGHTER = FASTER !!! |
The Dizzy is on the left side.
83 SC Targa -- 3.2SS, GT2-108 Dougherty Cams, 9.5:1 JE Pistons, Supertec Studs, PMO ITB's, MS2 EFI, SSI's, Recurved Dizzy, MSD, Backdated Dansk Sport Stainless 2 in 1 out, Elephant Polybronze, Turbo Tie Rods, Bilstein HD's, Hollow 21-27 TBs, Optima Redtop 34R, Griffiths-ZIMS AC, Seine Shifter, Elephant Racing Oil Cooling. |
