2002 996 C4S
jcsjcs's Avatar
Engine's Out - Projects?
I have my engine out for a Transmission Rebuild. My car is an '85 911 with about 102k miles on it.
Here is the list of projects I plan to undertake while the engine is out.
I am about $700 over my budget - so if there is anything that seems unnecessary or otherwise, I would appreciate any input. Also if there is anything that is obviously missing, let me know.
Clean Engine
Transmission Rebuild - Gary Fairbanks - TBD - $1500 to $2000 (as quoted based on problems)
Replace Clutch (Do I need to use Full Pelican Kit? over $1,000)
CV Rebuild or Replace - $60 vs $300
Valve Adjustment - Already have parts
Replace broken Air Valve - $25
Replace missing Air Box Hinge - $5
Replace damaged Wheel Studs (about 4) - $10 each
Replace broken O2 Sensor Connector - $35
Replace 2 x Oil Breather Hoses & S Hose - $100
Replace Starter cover (small plastic electrical connection cover) - $4
Clean and Paint Starter - $10
Replace Heater Hoses (with aerospace versions?) - $60
Replace damaged Shift Coupling Bushings - Already have parts
Install Precision Shift Coupler, if Bushings don't resolve problem - $195
Replace Ignition Electrical portion (behind Ignition Key) - $45
Upgrade Stabilizer Bar mounts to WEVO mounts - $195
Inspect Accelerator Linkage Bar and Connection - may be damaged - TBD
Replace Fuel Filter - Already have parts
-101 Projects - Recommended
Replace Oil Pressure switch - Adjustable - $65 or regular $75
Oil Thermostat O-Ring - .25
Oil Cooler Seals - $9.25
Replace Pully Seal - $12
Thanks!
jcsjcs
Have: '02 996 C4S
Had: '87 944, '84 911 Carrera Targa
Old 06-10-2010, 04:47 AM
Barrpete's Avatar
If you haven't done it already now would be a good time to R&R the leak prone fuel lines as described in this post:
Fuel lines sent to Amazon Hose Tampa for rebuild
1986 Carrera Coupe
1999 Chevy Tahoe
1987 Chevy Blazer
1955 Chevy Apache 3100 Pickup
"A little knowledge is a dangerous thing"
Old 06-10-2010, 07:30 AM
AutoBahned
RWebb's Avatar
search on engine + out for dozens of previous threads
copy & paste into editor, sort & collate for the world's most comprehensive list, which you can then prioritize by your wallet size or labor effort
Old 06-10-2010, 12:12 PM
Hi
Targa Me's Avatar
I'd replace the CHT sensor; both crank sensors, O2 sensor, Intake runner gaskets, fuel damper and fuel regulator and the fuel lines are a must.
If you don't replace the crank sensors at the very least make sure they have the correct gaps and before replacing the engine and put a small film of grease around them so if you have to remove them later, they'll slide out easily without removing the engine again.
"A good sense of humor is the best thing to have in your toolbox when working on these cars."
Quote by Charles Freeborn, Pelican.
Old 06-10-2010, 12:37 PM
MBruns for President
JeremyD's Avatar
rear monballs - much easier to put in with the engine out.
At 102 miles, I would probably replace motor mounts/transmission mounts.
Then what barrpete and targa me said.
DEFINITELY looks at your crank/reference and CHT sensor - if your CHT sensor is one wire - replace it even if it looks OK. DEFINITELY replace fuel lines -
Old 06-10-2010, 12:51 PM
Jack
Do yourself a favor, do the sound pad (if you want one) with the engine out.
-Jack
85 Carrera Cab
Old 06-10-2010, 01:07 PM
2002 996 C4S
jcsjcs's Avatar
I've been living and breathing "engine removal" threads for the last 3 or 4 months.
I will double check but believe I replaced motor mounts, transmission mounts, O2 Sensor 2 years ago. Also may have had CHT and Crank sensors replaced..
I am adding Intake runner gaskets, fuel damper, fuel regulator and the fuel lines to the list. I will check out the Engine Sound Pad too.
Great feedback. Only wish I had more $$$$.
jcsjcs
Have: '02 996 C4S
Old 06-10-2010, 03:16 PM
Might as well replace the hood shock(s) too. I'd like to replace mine but getting around the engine isn't worth the effort (for now).
If yours are sagging even a little might as well do it while access is easy.
Don't Lift... Don't Lift... Don't Lift
'75 Targa in "Arrest Me" Red, 3.0SC ('79) engine, Bilsteins, Turbo Tie-rods, SSIs into 2-1 M&K muffler... and looking for my next upgrade.
Old 06-10-2010, 04:34 PM
