Front hub/Bearing opinions
So I'm replacing the front right wheel bearings.
I have the old ones out & I notice on the outer hub that there is a build up of metal where it should sit flush (just in one part).
I'm thinking that when it was last done it went it crooked and scraped some ally from the side.
It is a quite solid lump. Should I just clean it up? The majority of the surface is square & should seat ok.
thanks,
see photos.
Old 06-11-2010, 05:06 PM
Member 911 Anonymous
DRACO A5OG's Avatar
Yeap, mine was like that when I put mine in. Apparently PO did not heat the hub to expand it before pressing in the new bearings, my 2 cents.
Question, beside economics is there a reason you are not replacing both at once?
'85 Carrera Targa
PCA/POC
Old 06-11-2010, 05:40 PM
If that was my hub, I'd probably replace it with a good used one. It's almost like the race was not pressed in and the guy drove it like that until the race spun. Someone would have to be really ham-fisted to do that damage, but it probably could be done.
I'd check the spindles for wear too. Mic the right side against the left side, and against the new bearing race.
Old 06-11-2010, 06:01 PM
Senior Advisor
James Brown's Avatar
When you have the new race pressed in, check to make sure that they just don't fall in.
08 Cayenne Turbo
Old 06-11-2010, 07:13 PM
Two Rivers's Avatar
Looks to me like the person that put these in the last time first dipped them in the dirt before using a sledge hammer to install them.I would find a good used set. I had one like that once. On a sunny day last year I seen a guy drop a piston he was installing in a 396 Chevy motor wipe it on his pant leg once and install it. Not on the garage floor, in the dirt drive way. So it will happen.NO I did not say anything just walked off. After he returned the ring compressor I just chucked it in the trash.
Old 06-11-2010, 07:19 PM
djpateman's Avatar
You are supposed to heat the hub to both remove and install the bearings. That looks pretty rough to me, but you might be able to salvage it.
Keeper of 356, 911, 912 & 914 databases; source for Kardex and CoA-type reports; email for info
Researching 356, 911, 912 & 914 Paint codes, Engine #'s and Transmission #'s
Addicted since 1975
Old 06-11-2010, 07:32 PM
If you mean both sides of the car, it's cos the other side has no play or noise.
If you mean both bearings on one side, I am !
Obviously the worst looking part is where the cap goes on! Which is of course not a prob.
It's a 33 year old car, so who knows when or how they were put in.
Old 06-11-2010, 07:56 PM
Senior Advisor
Heck, change all four! I think you will be fine and know one (mechanics) heats them up to remove or replace them, just a BFH and a brass punch.
08 Cayenne Turbo
Old 06-11-2010, 10:25 PM
Diss Member
Quicksilver's Avatar
If you do it right they do fall in. You heat the hub in the oven and keep the races in the freezer. If the races are nice and cold they will fall to the seat. One second later the surface of the race heats and it is firmly in there.
- "Speed kills! How fast do you want to go?" - anon.
- "If More is better then Too Much is just right!!!" - Mad Mac Durgeloh
Wayne - 87 Carrera coupe -> The pooch.
Old 06-12-2010, 06:50 AM
304065's Avatar
There is no way you will get the race to seat properly with the material in the hub moved like that. Replace the hub.
You must heat the hub to 150C so it expands enough to install the race. Wear foundry gloves and be careful, 150C will give you second degree burns.
'66 911 #304065 Irischgruen
‘96 993 Carrera 2 Polarsilber
'81 R65
Ex-'88 Carrera (Sold 3/29/02)
Old 06-12-2010, 07:33 AM
DRACO A5OG's Avatar
I meant Both Front Wheels.
'85 Carrera Targa
PCA/POC
Old 06-12-2010, 06:00 PM
