Help I.D this A/C...
Hi
Just got my first 911...1970E...I noticed these vents and tought it was an a/c equipped car,but the owner doesnt have any a/c parts...he said something about the a/c getting in the way of the engine performance,etc...
Since Im from Brazil and its kinda hot in here...I want to find out what sort of A/C is that...is it factory?Aftermarket?...help!!!
Thanks...
Dan
Old 06-09-2010, 12:30 PM
My other ride is a C-130J
RNajarian's Avatar
The setup looks similar to the dealer installed A/C in my 1975 S. However, I have two knobs, one for fan speed, the other for A/C temp.
Check for the front condenser in the passenger footwell area. My car has a cut out with the condenser there. If your car had A/C I suspect that condenser (or at least the hole) is there. If not then the setup is a fresh air fan, which works pretty well in my car.
1975 911 Targa S 3.0 2000 911 Carrera Cab 2005 Cayenne Titanium Metallic
2022 Mercedes-Benz E450 Coupé 2020 Mercedes-Benz E350 2006 ACG Hummer
Previously Owned Art from Stuttgart
2000 Boxster -1983 911 SC Cab -1984 944 N/A
Old 06-09-2010, 01:42 PM
Similar to dealer installed system.
Don't think there was ever a condenser in the pasenger footwell area. Would make no sense to put it there.
Almost all had the evaporator in the smuggler's box in the front trunk, ducted to the passenger compartment - to the vents under your dash. Return air for the evaporator was often in the passenger footwell. Possibly the evaporator could have been in the footwell, but never seen it.
Condensers were usually under the engine grille and/or below/behind the front bumper.
Compresser in the engine compartment.
Are the refrigerant hoses still on the car? (from evaporator, to compresser, to condenser(s)?
Old 06-09-2010, 02:11 PM
RNajarian's Avatar
Maybe it is an evaporator. I could have my terminology wrong.
The item in the footwell looks like a radiator (square shaped) and has a bendable wire "probe/sensor" which goes back to the temperature control on the facia of the A/C control unit in the vehicle cabin.
Old 06-09-2010, 02:21 PM
That's the evaporator.
Unusual. Most have it in the smuggler's box.
Old 06-09-2010, 04:12 PM
geoz's Avatar
Yep, evaporator. I believe it also sits there for all RHD cars.
Old 06-09-2010, 04:19 PM
kuehl's Avatar
Feels like a Coolaire brand system
Old 06-10-2010, 04:24 AM
Otto's Avatar
a/c
Dpd vpc
Racing Porsche for over 30 years.
http://www.OttosVenice.com
Check out the Porsche Owners Club Track event Videos
Old 06-10-2010, 03:10 PM
Registered Lunatic
A/C isn't really rocket science, A good pump (compressor), condenser, reciever/dryer, orfice (expansion valve) and an evaporator and viola. . . A/C.
If the evaporator coils are still in the smugglers box (and the blower unit, and it works) you can go from there. It's all just a matter of $$$.
First I'd isolate, flush and check the evaporator only (no line sets) to see if it will hold a vacuum. If that's good then any good A/C tech should be able to get you going.
I wouldn't trust any of the rubber hoses, so those will be costly, they can be made though, and even better hard lines can be installed for the long runs too if you want to go that route.
The original condensors were S-M-ALL, and I wouldn't think they would work well with r134, which would be the best refrigerant to use of course. The long lineset itself will help though. Remember, with A/C you're not cooling the air, you're removing the heat, and you have to dissipate that heat somewhere. If it didn't come with the car, stock condensors are available out there that will work fine. You may even be able to use one (as well as the compressor) from a mid 90's+ 911 that was designed for a 134 system.
However again, a real A/C tech will (should) know what would be the best size for the existing evaporator. He may, and probably should, even change the expansion valve (orfice) size too.
BTW getting that compressor mounted will take some engineering/fabrication too unless you can find an original mount to start out with. Even then, if you use a later model or different compressor you still may have to make some modification. I believe the original compressors on many aftermarket systems were the York rebuildables. I'm not a good enough A/C guy though to know how effecient these would be compared to the r134 specific ones of today.
If'n I tell ya a rabbit can pull a freight train, then son, hitch his ass up!
Old 06-10-2010, 03:28 PM
kuehl's Avatar
Otto,
I was thinking the old Coolaire out of Miami because of the location of the controls and shape of the vents. I always thought the VPC only had 4 equally sized vents.
Old 06-10-2010, 03:31 PM
kuehl's Avatar
Originally Posted by d.a.autry View Post
And on the eighth day, God set events in motion that would culminate in the birth of Ferdinand. And He looked upon Ferdinands future work and saw that it was good.
Well, maybe except for the Boxster and 996 engine.... LOL
Old 06-11-2010, 06:01 AM
Originally Posted by kuehl View Post
Otto,
You're correct. That's not a VPC unit. I have one in my car.
Coolaire sounds correct.
Old 06-11-2010, 07:59 AM
