NutmegCarrera's Avatar
Location: Plymouth Wi. - Spitting distance from Road America
Headlights on = no blinkers
I have an interesting one here - I think.
Over the winter, I did a bunch of stuff - including feeding a new antenna wire through the dash. In the process, I thought I was pulling out an old wire from a car phone. Wrong-o! The end had been affixed via a spade connector up in the passenger side corner of the dashboard. Near the footwell blower. Since I hate electrical work with a passion, and digging in the dash is a close second - I thought I'd wait until the car is operational and find out what - if anything is effected by my gaffe.
Well, the one thing I know is different is that the blinkers work fine when the lights are off, but when the headlights are on - the flashers remain in "on" all the time - along with the indicator lights in the tach.
So - what lives up in the right hand area of the dashboard (near passenger door / window) that I messed up by pulling a wire out?
Thanks.
Old 06-17-2010, 09:52 AM
Eddyvdw's Avatar
What's your cars MY?
Old 06-17-2010, 10:34 AM
It sounds like you are missing the ground wire to the tach. I had similar problems when I got my car.
'69 911 Targa w/ 3.2
Old 06-17-2010, 10:38 AM
dshepp806's Avatar
ground(s)...
Doyle
Recording Engineer, Administrator and Entrepeneur
Designer of Fine Studios, Tube Amplifier Guru
1989 Porsche 911 Carrera Coupe
25th Anniversary Special Edition
Middle Georgia
Old 06-17-2010, 03:46 PM
86 911 Targa's Avatar
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
Originally Posted by eddyvdw View Post
what's your cars my?
+1
1986 911 Targa.
Per Road and Track magazine:
Only in L.A.:
In the window of a bar in Hermosa Beach, California.
"Happy Hour prices during all car chases."
Old 06-17-2010, 04:06 PM
Duh.
It's an '85. Sorry bout that.
I need to dig into wiring diagrams, but if anyone knew answer to this - I'd be greatly appreciative.
Thanks!
Old 06-17-2010, 06:02 PM
Thanks.
So, what is the color code on the wire you removed?
Or, better yet, a picture.
1986 911 Targa.
Only in L.A.:
Old 06-18-2010, 08:35 AM
Mo money = mo parts
I had a funky left turn signal when the headlights were on, it turned out that I had accidentally switched wires on the right signal when I was cleaning connections. I was running power into the ground circuit.
So, I agree, it's probably ground related. In my case, I had nice clean grounds with the positive circuit connected directly to it
Greg
86 Coupe (stock - pretty much like Butzi designed it) - gone, but not forgotten
65 Ducati Monza 250 & 66 Monza Junior (project)
"if you are lucky enough to own a Porsche, you are lucky enough"
Old 06-19-2010, 05:48 PM
I believe the wire was brown. If I get a chance tomorrow night - will dig around in there and snap a photo.
Couldn't figure out what's located up in that area of the dash.
Hoping to have some time to troubleshoot soon...
Thanks for the hints, though!
Old 06-19-2010, 06:36 PM
80-911SC's Avatar
brown = earth = Porsche ground
now you just have to climb in and figure out what it went to ...........
Old 06-19-2010, 08:56 PM
Duh.
Thanks!
Here is a possibility from our '86 factory manual.
Look for an attachment point (grounding point) with several male spade connectors
with other brown wires under the dash, adjacent to the glove box area.
Also, just ground the "loose" wire and see if all is well.
Good luck,
Gerry
1986 911 Targa.
Only in L.A.:
Old 06-20-2010, 05:00 AM
winter
Winter's Avatar
Not sure for your model year, but in my '75 there's a wire that goes from the turn signal to the emergency flasher switch. Removing this wire causes funkiness with the turn indicators. . .
good luck.
Tom '75 targa.
Old 06-20-2010, 05:41 AM
Taking it apart is easy
Jerome74911S's Avatar
The grounds on these cars were designed by psychotic ogres living in dungeons, in the darkness. Check every (brown) ground wire you can find.
Jerome
PLEASE CHECK MY QUIZZICAL BLOG: www.ponderingporsches.blogspot.com
Old 06-20-2010, 07:05 AM
