RSR Engine Mounting Bars
I have been collecting photographs of RSR Engine bars for just over a year now
, which I realise is a bit sad but it is interesting to see all the variations of 'genuine' Factory engine bars that are out in the marketplace.I have seen photographs of a bar with only one return edge and with an array of 6 holes (Slidevalve RSR) which I tend to think may be correct. I have seen several bars where the first 'lightening' hole is 72mm diameter rather than the more common 60mm version. There is a bar manufacured in Switzerland which is made from 4mm thick material and another in the UK that is made from the 'correct thickness' which is not specified. (Standard bars being a nominal 3mm) I also have an SC/RS engine bar that has the lower return edge added by welding and the upper return has had its thickness doubled with welded strip. I am reasonably confident that this is genuine. Does anyone have any definitive photo/sketches of even a good description? |
Alii&Maui
Hey Chris, It would be most excellent if you can post pictures of your finding. I made mine using 3 holes spaced equally apart. Looks correct so I went with it.
1982 SC Coupe SCWDP#0087 KCSSL#0082 |
SWB Enthusiast
RR Engine Bars
I am just a bit concerned about posting other people's photo's, which is why I haven't done as you suggest.
![]() I would also like to see your collection of photos. Someone correct me if I am wrong, but once photos are posted I think they become public domain. I am looking for a photo of the latest RSR engine bar......... the 2010 GT3 RSR or however they describe the latest version. The alum crossbar on my 996 motor seems awfully inadequate and I would like to replace or reinforce it. Perhaps I will call Rennline to see if they have something like they do for the 964 & 993. Len
AutoBahned
the entire internet would collapse if no one was posting other people's photo's
Max Sluiter
This is a 997GT3 Cupcar, a few years old. I do not know where I got this photo, probably Porsche's website, but it is not mine.
1971 911S, 2.7RS spec MFI engine, suspension mods, lightened Suspension by Rebel Racing, Serviced by TLG Auto, Brakes by PMB Performance |
