dickster's Avatar
front strut top nut removal - help!
when trying to remove the top nut the strut just rotates - how do i stop this?
thanks
richard
Old 12-22-2001, 07:12 AM
strut nut removal
Their should be a flat surface to put a wrench on to hold the strut... At least their was on mine...Matt
Old 12-22-2001, 07:16 AM
dickster's Avatar
do you mean under the fender? mine is totally round under there..
richard
Old 12-22-2001, 07:32 AM
cary's Avatar
My guess ............
Is the key broke off your washer. That's what keeps it from turning. It fits in the slot on the strut.
You need an impact wrench. The speed will back it out.
BTDT
Cary
77 Carrera RS w/3.2 #59
73 914S 2.0 AG
73 914 1.7 Driver ( daily driver, under complete rustoration )
74 914 2.0, 71 914 Tub, 74 914 2.0 Tub + 73 914 donor
Old 12-22-2001, 07:58 AM
I had the same problem changing struts on my Neon. What I did was heavily wrap the strut shaft with shop rags, clamp it with vise grips, and hit the top nut with an impact wrench. I had to go buy an impact wrench. I couldn't get enough torque quickly applied by hand.
Jeff Parker
72T *Sold*
98 Neon R/T sedan, red
98 Neon R/T coupe, white
98 Neon R/T coupe, blue
Old 12-22-2001, 07:59 AM
dickster's Avatar
thanks i'll give it another go
richard
Old 12-22-2001, 09:20 AM
Clark Griswald's Avatar
I assume you are talking about the front.
There is a large cupped washer that sits on top of the struts rubber bushings. It is about 2.5 inches.
Grab it with a monkey wrench while you turn the nut. The washer has a tooth that engages the strut and prevents it from turning.
Use caution so that you don't scratch the fender with the wrench. Use a towel or fender protector to be safe.
Clark Retired, I'm now posting under my real name
Chuck Moreland
Day Job - Elephant Racing
Basic Transportation - '86 Cab - "Sparky", '77 Targa - "The Peaper"
Old 12-22-2001, 09:35 AM
Senior Member
Also look at the top part of the shock rod. Many of them have an "allen" type hole in them. You can put an allen wrench in the top to hold the shaft and then use a box wrench to loosen it.
I just used an air wrench and it came right off, easier in the long run if you have air at home.
Old 12-22-2001, 01:16 PM
Otto's Avatar
Jack the car up, take a pair of vice grips to the exposed shock shaft between the dust cover and the bottom of the mount under the fender. The shock shafts are made of old melted down Panzer tanks and you can't scratch it. OTTO
Racing Porsche for over 30 years.
http://www.OttosVenice.com
Check out the Porsche Owners Club Track event Videos
Old 12-22-2001, 02:07 PM
dickster's Avatar
finally did it today - the monkey wrench worked a treat.
richard
Old 12-29-2001, 06:11 AM
ClayMcguill's Avatar
Talking
So THATS' what happened to all those Panzers. (Ferdinand was into recycling, even back then? Huh.)
I ended up using my impact gun to zip the nuts off (elapsed time-2 seconds.)
Clay McGuill '66 912 My 912's restoration website, '97 Jeep Cherokee, '70 Ford Bronco My Bronco's rebuild site
Old 12-29-2001, 03:15 PM
