Registered Lunatic
What's up with this interior issue?
Okay. . .I haven't snapped pics of mine yet, but I think I can use a pic I found on here to demonstrate.
Look at the circled area on the pic below showing where door panel meets dash. Now, in this pick the lines where they meet are nice, straight and pretty much appear to be parallel. However my door panel to dash does not meet up straight and parallel like this. It's more like the little red V I drew on this pick with the bottom edge almost touching. Any clue as to what could cause this??. . .different year dash or panels maybe??
If'n I tell ya a rabbit can pull a freight train, then son, hitch his ass up! Last edited by d.a.autry; 06-25-2010 at 02:23 PM.. |
Without a PIC, I'd guess warped dash.
Registered Lunatic
The dash 'looks' good, no obvious signs of warpage. . .I was wondering that too myself.
I'll see if I can get a quick phone pic in just a few moments.
If'n I tell ya a rabbit can pull a freight train, then son, hitch his ass up! |
leather interior.
Ruby911
Mine does that too and I believe it is because I have an '84 with a later model leather dash.
1984 Carrera - SW Chip, Factory Short Shift Kit, Cat Bypass - SOLD 1968 Ossi Blue 912 Sunroof Coupe - SOLD 1971 911E - 2.7 Twin Plugged, PMOs - SOLD 1965 356C Outlaw RGruppe #577 |
Registered Lunatic
No. . . I had some naugas give up their hydes for my interior
![]() Here's a few pics, the passenger side appears worse in this, but they're both about equal. That's kind of what I was thinking Ruby. . .the colors between the dash and door panels look just a hint off too. ![]()
Ruby911
yep, that is exactly what mine looks like. I do my best to ignore it. :-)
The dash also has clips that hold it down from the underside. If these clips are not secured properly or if they broke this could mean the dash isn't seated properly. Can you lift up on the dash at all? These buttons are kind of a PITA to fix and there are a lot of fasteners holding the dash in place.
do the doors close properly with a consistent reveal around the edges?
(1) '77 Chassis and '79 SC 3.0 project car (1) '79 911SC 3.0 Widebody SC (1) '15 Ford F-150 4x4 3.5TT Toluca Lake, CA |
Registered Lunatic
Yeah. . . has to be interior mismatch then. Ignorance IS bliss!
I don't know the history of this car and it's been a little disconcerting. I checked the tub well for signs of it being clipped and didn't see any (and I wouldn't think that even the worst hack would have done that bad of a job on a clip either) Just wanted to confirm my thoughts that it was a mismatch. I would almost assume it's a different year dash as this is in a '76 chassis and has no cracks.
If'n I tell ya a rabbit can pull a freight train, then son, hitch his ass up! Last edited by d.a.autry; 06-25-2010 at 02:10 PM.. |
Registered Lunatic
Nah. . .pretty darn solid. . I thought of that too, but when you look at the angles and what it would take to bring them into alignment you realize that in doing so the front of the dash (at the windshield) would sit up over an inch above the windshield seal, and the edge of the dash would be pointing more downward than normal. I thought of that, of heat warpage, of course had nightmares about a bad hack job on a clip car. . . It's 99.9% an interior mismatch here. (There's NO place like home. . there's NO place like home) LOL The doors do close well, however they seem out of alignment at the bottom on both L and R. It's as if the bottom hinge needs to be adjusted inwards towards the center of the car where it attaches to the body, however there is no adjustment that I can find there (unless that particular adjustment is internal on the door itself with shims). . . Another weird thing is a bit of leakage on both sides. On the drivers side it will leave a few drops near the headlight switch. . but this appears to be coming in through a bad windshild seal. As best as I can tell it seems to be coming from behind the dash, and not from around the door seal.
If'n I tell ya a rabbit can pull a freight train, then son, hitch his ass up! Last edited by d.a.autry; 06-25-2010 at 02:05 PM.. |
my cork dash on my 79 911 didn't look like that. FYI
Registered Lunatic
I'll have to take better note of other dashes on similar year models at the next event I attend.
Also. . on my door issue. I'm wondering actually if front fenders could be out of alignment at the bottom. Checking things like that are on my list of 'down the road' projects.
Registered Lunatic
And yeah T. . .I PIC'ED up on that 'edited a pick' thing. . . LOL ![]() Leaf my spelin aloan!
If'n I tell ya a rabbit can pull a freight train, then son, hitch his ass up! Last edited by d.a.autry; 06-25-2010 at 02:24 PM.. |
If the leather isn't warped around the A/C vent and and W/S vent holes then it's not warped leather because it would shrink away from there first. Also it's not the plastic snaps since the front of the dash is anchored by 6mm studs at both ends of the dash.
I'm wondering if the dash front were rotated and it could be re-installed so the ends would be aligned. I would talk to Tony Garcia at AutoBahn Interiors, San Diego, I'm sure he could tell you where to start. I agree having to look at that would make me crazy, if it were black it would be so noticeable. Plus Cork interiors are my favorite anyway.
Mitch Leland "03" 996 C2S-LS3 V8-480 HP "84" 911 Turbo Look-Sold w/ found memories |
AutoBahned
take an angle grinder to the leather
Registered Lunatic
I'm figerin' on the sawzall. Why clog up my disk??
my 83, with the original dash and doors, is exactly the same.
- He gave his father "the talk" - Once while sailing around the world he found a shortcut - He taught a german shepard how to bark in spanish He is.... nineball. I don't always drive sports cars, but when I do I drive a 1983 911SC Targa. Stay fast my friends. |
I see the same on my '89.
Doyle
Recording Engineer, Administrator and Entrepeneur Designer of Fine Studios, Tube Amplifier Guru 1989 Porsche 911 Carrera Coupe 25th Anniversary Special Edition Middle Georgia |
Registered Lunatic
Not wishing ill on the others that have this issue too. . . .but I'm sure glad to know that it's not just me. Like I said, it's been a little unnerving up until now.
I might just give Tony G. a call next week and see if he knows the reason for this. @ Doyle. . . LOL. . . . tubes!! Believe it or not, I had a prof. at S. Tech that swore you could get just as good of a reproduction on sound with linear op-amps. . . . until I wasted him with a pair of silver sevens by ear and lab results . .(I know. . .Bob sucks). . . Then I proceeded to use an old SAE to show that even older solid state amps would waste him. Strange, even though I aced all tests in his class, he wouldn't give me above a B on any of my lab work. . . wonder why??
If'n I tell ya a rabbit can pull a freight train, then son, hitch his ass up! Last edited by d.a.autry; 06-26-2010 at 05:14 AM.. |
Tubes have they're own sound,..although one must have the professional ears to appreciate /differentiate it. Instrument always proved my points. I will say that they're getting better on the SS stuff,..at least the high end hardware, where there exists no compromises.
I'm a big fan of "even-order" harmonics,..and cathode-bias on guitar amps. Best to you and yours', Doyle
