Send a message via ICQ to Kurt B Send a message via Yahoo to Kurt B
Post Tapping from distributor?
Kinda strange, but I took off the dist cap, rotor and cranked the engine. The tapping appears to be coming from inside. There's a pair of "thingamajigs" that swing out under the cent. force and they maybe rub against two other "thingamajigs".
Anyway, these things slapping or ticking against these appears to be the sound. There are two springs that hold the first thing together...one of the plastic housings on these appears to be broken, making the spring on one side maybe slightly less tight..but this does NOT appear to be the cause..it's not as though a spring is missing, or something..the spring is on there, but maybe 1/2 mm less distance...
Anyone know anything about what's going on in here..
Put it this way, if I take off the cap and crank it, should I hear those pieces ticking as the engine turns?
Kurt B
1984 Carrera Cabriolet
911 Page
carrera_cabriolet@yahoo.com
Old 06-27-2001, 08:53 PM
twin plugged targa's Avatar
Post
OooH!
I dunno Kurt sounds abit dodgey to me!
If the car is running right am sure it's fine!.
This dose'nt sound like the usual 'happy go lucky -drive it till it explodes -Kurt B' we know?
You've been reading too many of my threads
Old 06-28-2001, 04:23 AM
Senior Member
Superman's Avatar
Post
Kurt, I do not believe these things should be making noise. Warren has repeatedly told us our distributors need to be removed, disassembled and cleaned. Ignore Warren at your own risk. I do.
Also, I have to agree that the two of you are big, big joys to the rest of us on the Board. Oh, and I suspect that the broken plastic thing needs to be replaced or fixed. There aren't many things on my car that are not there for at least one very good reason.
'83 SC
Old 06-28-2001, 03:49 PM
