VIN Number Engine number question
I have a 911 with VIN Number of 91133017XX (not really X's)
![]() When I check the Fahrzeugidentifikation website the range of numbers for 73 911S is 9113300001-9113301430 which is under my last four digits of 17XX. My engine number is 6131104 which possibly is in the 911T range but I can't find that number on the list either. Can anyone help me confirm these numbers as I don't see either of them matching up on sites I have checked? THANKS!! |
My reading of the site confirms that 91133017XX is beyond the range of S cars. I would only say that you need to be absolutely certain that the eighth digit is a 7. There are stories of S cars being rebodied, and this may be the case here, but I am no expert on this.
As far as the engine number, the range of T engines is from 6130001-6131926 for type 911/51 and even greater for type 911/61, 91, and 96. All these engines would include your 6131104.
L.J. Recovering Porsche-holic Gave up trying to stay clean Stabilized on a Pelican I.V. drip |
Thanks ossiblue. Yeah it does look like the engine is in the 911T range. I confirmed again that the eighth digit is a 7 on three different locations I found the number.
By the book, the only model range of '73 cars that extends into the "1700" range are the RoW coupes (fitted with carburetors) where the 5th digit is a "5".
Keep the Shiny Side UP! Pete Z. Last edited by Peter Zimmermann; 08-22-2013 at 10:29 AM.. |
I love to figure out anomalies like this. The engine should be a US 911T type 911/51.
I'm curious about the fifth digit in 91133017XX, is it really a 3 or perhaps a 5. I think it really should be a 5. It is not unknown for the factory to mis-stamp the numbers. Photos would help me a lot. If you want to do it privately, then PM me for my email address.
Keeper of 356, 911, 912 & 914 databases; source for Kardex and CoA-type reports; email for info Researching 356, 911, 912 & 914 Paint codes, Engine #'s and Transmission #'s Addicted since 1975 |
The three places I see the number are on the car. Stamped under trunk by where the spare tire would be. Inside near windshield pillar and chassis ID plate under where the trunk lid latches.
Can you read the type number of the engine, stamped just forward of the engine number on a horizontal part of the engine case? It will be a "911/xx".
Keep the Shiny Side UP! Pete Z. |
This could get interesting.
Suggest you also check under the knee pad below the dash fascia - this number should match the one you found stamped in the trunk rearward of the gas tank.
This is not correct. The stamped #on the lower portion of the dash frame under the knee pad was the VIN only to the end of 1968 model year, and from 1969 MY (to well into the 1970's at least) it was a production # that bears no resemblance to the VIN.
I am a real newbie. How can I tell if S brakes? |
As far as the production number, someone has to go to a lot of trouble to obliterate it so it's very likely this was done to obscure the true identity of the chassis. In your case, probably to pass a non-S chassis off as an S. I wouldn't be too concerned about the brakes (you can do a search for "S brakes" and get a photo of the differences) because all cars had the option of these brakes, plus S trim and gauges. If someone was trying to pass off a non-S chassis by altering the VIN and removing the production number, then I'm sure the S add-ons were included as well. If you can, post as many pictures of areas mentioned, or any other areas that others offer up as that is the only way (short of an in person inspection by an expert) to help you solve this mystery.
L.J. Recovering Porsche-holic Gave up trying to stay clean Stabilized on a Pelican I.V. drip Last edited by ossiblue; 08-24-2013 at 09:21 AM.. |
I have seen the photos of the various tags. The windshield VIN tag does not have the raised edges of the original, and the manufacturers tag on the front slam panel is a painted/printed tag unlike a real tag. So, two non-original tags and drilled out production # are strong indicators of falsification. See this original windshield VIN tag:
