anyone know what part this is???
Newbie diving in headfirst into '85 3.2. While I was replacing my engine lid shocks, I came across this cable that was ziptied to another part. It starts running from yellow section of the cylinder that is on the firewall (also in the photo), goes over the engine and then loops back around to a screw type end where the mounting bracket is ziptied. Any ideas. If you need more photos, let me know. Thanks in advance.
Dave Black 1985 911 Carrera M491 |
Cruise controll cable.
1986 3.2 Carrera |
Thank you! Where should it be mounted?
Senior Advisor
engine
08 Cayenne Turbo |
Goes towards the rear of the car and makes a u turn and attaches to the throttle. Should be a mounting bracket nearby that the plastic end fits into. Ken
Ken in Greer, SC 88 Carrera Coupe 98 C2S Coupe |
Senior Advisor
It was probably off for a reason. Like it did not work, you could spend a lot of cash to get it to work properly. But they are handy.
08 Cayenne Turbo |
Cruise cable
Here's a shot of the cruise control cable attached. The cruise control module is known to have cold solder joints thus not operating (properly or not at all). The cruise control module is located under the dash and is easy to get at. All you need to do is re-flow solder over a bunch of suspicious joints. This cured my cruise control and it now works great, but I rarely have opportunity to use it; but, hey it works!
Henri '87 Carrera coupe: Venetian blue |
Thanks all! That picture will help a ton. Very nice clean engine, Hendog.
just leave it off it's no cadillac
1973 911S (since new) RS MFI specs 1991 C2 Turbo |
I think ol' Porsche would've said "our cars are meant to be driven , not cruised" ;<)
But I guess like AC and the like, the US market dictated the add ons.
'81 924 , '85 944 , '78 911SC , '82 928 5.0L "They run best being run close to the ‘limit’ and done so regularly" - Grady |
