5String
Odo/Speedo Question
A quick search seems to suggest that when the odometer in an SC speedometer quits working, it's the famed plastic gear that's causing the problem.
Is this indeed bulletproof, or can there be other reasons for this?
I'm told that if the speedometer works but the odometer doesn't, there can't be anything wrong with the sending unit or its connections. True fact?
Thanks in advance.
5String
Tell not a soul that you have seen me; breathe not a word of what I say....
The Northwest Files
Old 07-03-2010, 11:26 AM
86 911 Targa's Avatar
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
Thanks in advance.
That's correct.
Search will help you out.
Thrasher posted a great step-by-step fix.
The only risk is bending/breaking the needle shaft,
and distorting the ring that holds the assy together.
I did a risk/reward and took mine to Paul's Speedometer in Redondo Beach.
$115 including the gear and calibration.
Good luck,
Gerry
1986 911 Targa.
Per Road and Track magazine:
Only in L.A.:
In the window of a bar in Hermosa Beach, California.
"Happy Hour prices during all car chases."
Old 07-03-2010, 12:38 PM
