Poor-sche Lover's Avatar
Another "Identify this Part" Thread
Pretty self-explanatory.......
I found it in the glove box of the new car. Porsche part? Maybe part of the tie rod end or something? It does have a stud/nut on the other side identical to the one you see. Thanks in advance.
Alan
Past: '74 914 2.0, '82 911 SC Targa, '88 911 Cabriolet, '88 911 Cabriolet again
Present: '00 Boxster S
"Happiness is not around the next corner......happiness IS the next corner."
Old 08-26-2010, 09:07 PM
Danny_Ocean's Avatar
Looks like it could be part of the window regulator assembly.
Old 08-26-2010, 10:00 PM
I seem to remember the part, center is rubber? I believe it was in the spare parts given to me by the PO. Mine had a thin piece of metal, maybe brass clamped in it. Seem like a mount for something. Never found its origin, though.
Old 08-27-2010, 05:06 AM
MBAtarga's Avatar
muffler bearing isolation mount
Mark
'83 SC Targa - since 5/5/2001
Old 08-27-2010, 05:53 AM
Senior Member
Superman's Avatar
Flux capacitor drain plug.
Mocha 1978 911SC. "Coco"
Old 08-27-2010, 06:56 AM
techman1, that sure sounds like it. Yes, the center is rubber, dry as it may be. As you can see, there are two sleeves through which the stud passes.
Alan
Old 08-27-2010, 08:54 AM
No other thoughts?
Alan
Old 08-28-2010, 05:04 AM
Weekend Mechanic
vulcan300's Avatar
It looks very similar to the vibration isolation mounts for the front oil cooler.
@Superman - Only 914s and Deloreans had Flux capacitors :-)
86 911 Carrera Targa
Old 08-28-2010, 06:17 AM
FrinkFrog's Avatar
Send a message via AIM to FrinkFrog
That's my vote, top iso mount for the 28 row brass oil cooler.
'83SC
'76 911S - Sold.
Old 08-28-2010, 07:22 AM
