Position of 911SC logo on rear deck lid
Hi,
I've been searching the forums as I'm sure this has been discussed/documented before, but I can't find it. Can anyone tell me the positioning of the "911SC" logo on the rear deck? Thanks. Geoff
'82 911SC (Complete rebuild) Click here to go to the project website that chronicles the rebuild process |
The 911SC emblem is made to fit a set of holes drilled through a correct lid. Are you trying to fit one to a different tail? This is what I did, with double-sided, super-thin sticky tape, when I added a 3.2 Carrera tail to my car...
Keep the Shiny Side UP! Pete Z. Last edited by Peter Zimmermann; 07-06-2010 at 05:01 PM.. |
Pete,
When I painted my car, I prepared two deck lids. I bought a tail and wanted to have the option of going with our without the tail. I've had the tail on the car for almost a year now, and pulled out the other deck lid and wanted to mount it to see how it looks. When I prepped both deck lids, I filled in all the mounting holes, so I don't have any reference for where the logo goes. You're showing one with a tail mounted - I think without the tail, the 911SC logo is mounted a bit higher, right under the grill. I need the exact position so I can drill new holes. Thanks. Geoff
I set up my car based on where the "Turbo Carrera" was put on a 3.0 Turbo, and my body guy did such a fantastic job closing off the original emblem holes that I cant find them on the underside of the original lid! I will look for a template in my factory manual tomorrow...
Keep the Shiny Side UP! Pete Z. |
Mine is exactly 13 and 1/16" from the top lip of the decklid to the top of the emblem in its center. And it is exactly 13 and 5/16" from the left lip of the decklid to the left side of the emblem.
A nose heavy airplane flies poorly, a tail heavy plane flies once. |
83 911 Production Cab #10
Did the scrip originaly had 5 pins, and you cut them off? I presently have a Carrera scrip that seem to have been glue on as there are no speed nut under. J.J.
Who Will Live... Will See ![]() ![]() ![]() 83 911 Production Cab #10, Slightly Modified: Unslanted, 3.2, PMO EFI, TECgt, CE 911 CAM Sync / Pulley / Wires, SSI, Dansk Sport 2/2, 17" Euromeister, CKO GT3 Seats, Going SOK Super Charger |
Carrera emblems were all stick-on, that's why you see so many of them incorrectly placed on re-painted cars!
What is the easy way to remove the present one with out leaving marks?
That is a great question, for which I have no answer! If you want to replace it with a new one you won't have to worry about paint fade, etc. I'm guessing that getting the old one off can be a combination of heat, Goo-Gone (sp?) or similar, and dental floss, but before trying it I would definitely talk with a body shop that repairs/paints 911s!
Thanks Pete
Thanks for the replies and placement position. Now I'm wondering if I should file the pins off and stick it on - sounds like a neat way to do it.
Geoff
My factory manual does not have an emblem template, sorry!
If you are not running a tail, then it's exactly 2 inches from the bottom of the grill outlet to the top of the "911" in "911 SC".
If you are running a tail, then it's about 7 inches or so from the bottom of the decklid to the bottom of the script. |
This is for a Carrera, but it might explain what I'm measuring. A visual usually helps.
Wash. State
This should have been answered by someone with a stock, original SC right at the start, for crying out loud.
Maybe get a Carrera and go through the same process. The SC had HOLES at least! Come on... ![]() I appreciate the Carrera info; and I think Peter's work looks good, but I'd "raise" it one inch.....
rusnak, I'm not trying to be a smart ass, or argumentative, but when I was an apprentice my boss asked me to make a measurement for him. It didn't go too well, so can your measurement include a diagram, or at least a clarification? Please?
Pre-tail, the only pic that I can easily find...
Another one:
Jess 1980 911SC Euro 1993 Audi CSQ |
I can certainly appreciate Pete's point regarding ambiguity.
I did go outside and measure a bone-stock 911SC. Here's where I got the 2 inch measurement:
rusnak; you are a good man! And tyro, thanks for the great picture!
Keep the Shiny Side UP! Pete Z. Last edited by Peter Zimmermann; 07-08-2010 at 07:46 AM.. |
