NGK Iridium Spark Plugs - Any comments?
Does anyone have any experience with NGK Iridium spark plugs?
Old 08-12-2003, 10:22 AM
Friend of Warren
Someone asked about them last week. Too me they are overpriced. Why not just stick with plain old NGKs?
Kurt V
Old 08-12-2003, 10:35 AM
Certified Pre-Owned
BGCarrera32's Avatar
I'm curious if anyone has experience with Bosch Platinum +4's in a 911. They have a 4 pronged tip on the plug and the box says you never need to gap them out of the box...
Trying them in my rice car, so far so good.
'84 Carrera Coupe
Old 08-12-2003, 01:24 PM
Send a message via ICQ to old_skul
Bosch Platinum anything basically get a bad rap in these parts. Stay away. The spark always goes from one electrode to another - never from 1 to all 4. There's no advantage. It's just psychological.
The NGK Copper plugs have never let me down.
Mark Szabo
1986 911 Targa 3.2 (I will miss you)
1985 Scirocco 8V (I will not miss you)
1986 Dodge B150 Ram Van (I can't believe I got $200 for you)
1987 Escort 5-speed 1.9 RIP
Old 08-12-2003, 01:32 PM
tobluforu's Avatar
I have them in my turbo saab, and they have by far outlasted any copper plug for that car. But they are way to expensive for non turbo's. Do they make my car run better? Nope! Just last longer.
Old 08-12-2003, 02:23 PM
Pat S's Avatar
I run denso iridiums in my supercharged toyota solara and they perform very well. I went with them because I needed to go one step colder, they were well tested at my level of boost and application, and they were easy to find.
Current: 07 S4 Avant, 06 Volvo S60R
Sold: '74 911, 01 986, 93 Volvo 240
Old 08-12-2003, 04:33 PM
c2 rower's Avatar
Have you ever heard of Unobtainium? If you replace clapped out plugs with any new plugs the car will run better.
Big Hooters and 911's will always be in style
Old 08-13-2003, 02:20 AM
Unhappy Fouled Bosch +4 plug
I have tried Bosch +4 plugs with similiar poor results on two cars. Both are Volvo 240s. One is 30 years old and the other is 20 years old. In both case 1 of 4 plugs fouled. the O2 system "saw" the unburnt fuel as a rich running car and leaned down the mixture. So, 3 plugs were running lean and therefore a bit hot.
Old 07-07-2010, 07:51 PM
I use them in my 73S with MFI. I believe that the car does start up a little better, especially with a rich idle mixture.
Old 07-08-2010, 03:13 AM
db_cooper's Avatar
Good plugs, very pricey. A better NGK to use would be the NGK BP6ET (3.2 engine). They will last longer than the copper plugs. Durability is excellent. You will have no regrets.
Old 07-08-2010, 05:33 AM
Schwarzeritter's Avatar
Location: PaloAlto Calif, IndianWells PalmDesert, Japan
In my experince depended on a particular engine. Like a
3.0 or 4G63 or 4AG, M52, etc and then it trickled into say if modifications or tuning was carried out.
You also have to becareful about gaping. It is possible in particular engines to gap and basicly have piston to plug contact. It depends on application.
Old 07-08-2010, 06:15 AM
cdrik915's Avatar
My experience with NGK Iridium : on a 911 3.2 /1986 model , that runs fine : i heard a noise a bit like a "click-click" , i checked springs valves , rockers arms ...............always tor Boschhis noise.
Just for trying , i changed my NGK for Bosch spark plugs.............and the "click-click" has dissapeared.
Try to test the Ohms resistance of a NGK ; you'll see that every sparkplug has a different value , that i can't explain.
All that i'm sure is that the taping noise is solved.
LIGHTER = FASTER !!!
Old 07-08-2010, 06:52 AM
tobluforu's Avatar
Until you go to gap them and break off the tip. Back to the cheapo plugs for me.
Old 07-08-2010, 07:26 AM
RETIRED
Joe Bob's Avatar
Use what is recommended...the expensive plugs are just expensive snake oil.....
Old 07-08-2010, 07:27 AM
Luv'em
I have used them on everything from 3.2 L Carreras to John Deere 335 lawn tractor to Audi A8 and even mfi 911's. I bet they would also work well in carbed 911's where the plugs have an issue with carboning up. They last forever, hold their gap well and start ups are fast...which helps on the starter. They are not even close to expensive compared to Denso's.
Old 07-08-2010, 08:51 AM
DanielDudley's Avatar
I use them in my supercharged Miata, and they are recommended for bosted applications with water or methanol injection.
I use the Bosch copper in my Porsches, because they are from the same era, and work well with Bosch Fuel Injection of that era.
Old 07-08-2010, 09:21 AM
The NGK is also a good plug. Bosch Platinums can fluff in a 911.
Old 07-08-2010, 09:23 AM
db_cooper's Avatar
You don't need to gap them. Just look and insure the ends are not damaged in the packaging. NGK factory settings are better than I could do on the bench. They do great right out of the box. Try them, no issues.
Old 07-08-2010, 12:45 PM
tobluforu's Avatar
You do when you are running over 23 lbs of boost and it blows open the gap after a while, different car though.
Old 07-08-2010, 01:14 PM
mikesride's Avatar
Have never had a better plug than the BERU quad plats that are currently in the car. Who's recomending Jap plugs in a Porsche to you guys anyway?? whats next a cheap set of champions? Ha! Ha! Just kidding guys! ALWAYS USE WHAT YOUR COMFORTABLE WITH AND UNDERSTAND!!
I've driven alot of crap to get here man!
Old 07-09-2010, 07:31 AM
