Kendall's Avatar
Send a message via Skype™ to Kendall
Proper Jack Points for 1987 Carrera
I am looking for the correct jack points for using a lift with my 1987 Carrera. I would appreciate any suggestions or links if available.
Kendall
"Chance favors the prepared mind."
Old 07-13-2010, 06:30 PM
silver911rdb's Avatar
I think in '87 Porsche added jacking points to the 911 chassis. The front mount should be lined up with the rear most section of the front fender. The rear mount should be directly underneath where the rear spring plates go into the chassis.
-Rich-
1984 911 Track
1985 911 Track/Autocross
Old 07-13-2010, 07:35 PM
Yep, just ahead of the rear wheel and just behind the front wheel along the rocker panels. They are kinda small but they are there. Watch the AC and oil lines. Ken
Ken in Greer, SC
88 Carrera Coupe
98 C2S Coupe
Old 07-13-2010, 08:40 PM
NewfieMZ3's Avatar
search lift points..........
1984 911 Coupe
2007 Z4 M Coupe
2008 Cayman S
2004 M3-Alpine White(sold)
2002 M Roadster (sold)
Old 07-13-2010, 10:31 PM
My 88 gets lifted by the center of the engine in the rear. By far the safest way. Those 6 ton jack stands that you have sitting around that are too big for anything are perfect for the rear height when the torsion bar covers sit on them.
The front cut a 2x4 to go on the channel between the torsion bar mounts and put the jack stands under the mounts.
Rick
88 Cab
Old 07-13-2010, 10:50 PM
Formerly known as Syzygy
Canada Kev's Avatar
I think he is referring to using a lift. My '87 has jacking points at basically the four corners of the main pan, behind the front wheel and ahead of the rear.
Kevin
Old 07-13-2010, 11:12 PM
Driver8's Avatar
Check out this thread.
Chart/Map of Jack points on 88 911
Old 07-14-2010, 07:19 AM
