Chart/Map of Jack points on 88 911
I'm looking for a refernence chart of proper jacking points for my88 911 coupe.
Want to jack it in the right place and would love a chart!
Thanks,
Kevin
'88 911 Silver Coupe
www.CoachKevin.com
Old 06-29-2004, 11:11 PM
Bandwidth AbUser
Jim Richards's Avatar
Kevin, I don't have a chart with me to post, but on the 87-89 Carerras it's very easy to spot the jack points. There are 4 square jack points, 2 on each side, one forward of the rear wheel arch and one aft (nautical lingo) of the front wheel arch.
Jim R.
Old 06-30-2004, 04:52 AM
If you look at the 2 pics I posted on this thread, you can clearly see what Jim is referring to (at least the rear shot is obvious). That's what I rest my car on when on jack stands, but use a jack pad inserted into the rocker 'jack points' on each side to actually raise the car. Raise one side of the car, place on jack stands, then raise the other side. Caution: Take it slow & easy...if I'm raising (or lowering) my car more than a little bit, I'll do each side a little at a time.
Front suspension powder coating- which parts?
Old 06-30-2004, 05:09 AM
Bill Verburg's Avatar
arrows C and D
In addition the point just inboard of the stock jack slots
and of course the engine
Bill Verburg
Old 06-30-2004, 06:44 AM
Your '88 has a small jack point just behind the front tires and just in front of the rears. It's a bump about 1" tall and 2" across.
Old 06-30-2004, 06:50 AM
Am I missing something in the question here? In the diagram that Bill posted, points C & D indicate the positions where the 2"x2" pads (that Steve references) are located (on the Carreras). But for actually jacking the car up (unless you're using a lift, etc. and raising the car using all 4 'pads' at once), are you guys suggesting that these points be used to actually jack up the car? I don't see how...please explain. Why wouldn't one use a jack pad inserted into the rocker 'jack point' (unless rusted, etc)? Thanks...Keith
Old 06-30-2004, 07:01 AM
Chris Lovell's Avatar
I use the jack points primarily for placing jack stands after lifting the car with the rocker panel inserted lifting pad. But I have also lifted the car from these jacking points and the engine technique (trusting Chris Bennet implicitly). The short wheel base of the 911 does make high lifting from a single jacking point dangerous (tipping factor).
CWL
'88 Carrera Cab
Old 06-30-2004, 07:31 AM
BTW, Bill's photos/graphics are superb. Thanks.
CWL
'88 Carrera Cab
Old 06-30-2004, 07:32 AM
Thanks - that was extremley helpful - the suggestions and pictures are exactly what I was looking for!
Thanks a million,
Kevin
www.CoachKevin.com
Old 06-30-2004, 03:42 PM
Automotive Monomaniac
Emission's Avatar
Bill, great images with your post!
2018 - Porsche 911 Carrera 7MT / 2018 - Porsche Macan 7DCT / 1993 - Cadillac Allante / 2023 - RAM TRX (on order)
Old 06-30-2004, 04:51 PM
thinkfloyd14's Avatar
Send a message via AIM to thinkfloyd14
I am going to paint my wheels tomorrow and would like to know if there is a similar spot to jack up the whole FRONT of the car, I understand the way to jack up the rear is the engine, and then supply the jack stands at both D points, but how would I do this to get the front of the car up so I can put jack stands at both points C??
I hope my question is clear and would love a simple answer to a complicated question.
Thanks,
Sammy
1976 911S
http://imgur.com/aSW9DtX
Old 12-03-2009, 05:18 PM
geoz's Avatar
+1
i'd also be grateful for ideas on how to get a jack underneath the front splitter rubber lip ... i need to replace the airco crash bar & protector and need to get underneath
cheers
hg
1988 911 Cabrio
Old 12-03-2009, 06:39 PM
Navin Johnson
TimT's Avatar
Drive the car up on a short piece of 2X6...then you should have clearance to get a jack under the front of the car..
'69 911 GT-5
'75 914 GT-3
and others
Old 12-03-2009, 07:29 PM
disband
juanbenae's Avatar
subscribed!
Old 12-03-2009, 07:34 PM
Navin Johnson
TimT's Avatar
Upon reviewing the thread..
Raise the front of the car enough by driving it on to some 2X lumber... jack the car via the front cross-member "A" , place jack stands near bushings at "B"
do what you gotta do
'69 911 GT-5
'75 914 GT-3
and others
Old 12-03-2009, 07:35 PM
THECARREAPER's Avatar
ok, i have had several 911s. i do read the owners manuals sometimes, as they actually have good info in them. the manuals clearly say NOT to jack up the 911 by its engine. my 85 Carrera manual has the warning on page 76.
so is it, or is it not, ok to raise a 911 by its engine case?
i have done it, but i do wimp out and use a heavy piece of rubber on the jack pad to cushion the load a bit.
this is a great thread, i did not know there were so many hard points on the underbody. i am going to be working on my 85 targa and my 87 slopenose this weekend. should be lots of floor jack use i am sure!
Old 12-03-2009, 07:48 PM
47silver's Avatar
if you use the engine
use a thick roll of newspaper (the sunday new york times) to cushion the bad against the case.
1975 911S Targa
Silver Anniversary Edition
Old 12-03-2009, 08:22 PM
Hey All,
I am looking under my 88 Carrera Cabrio for jacking points. I have to rebuild all of the brake calipers and replace all of the rubber brake hoses from not using the car much. I bought it new and it has only 15k on it.
I want to jack up the car and put 4 jack stands on it, so I can do all the wheels but one at a time..
Should I use points C&D for jacking and the jacking tubes for jack stands? Or the torsion bar caps for stands?
Jack
1988 911 Carrera Cabriolet
Old 07-08-2010, 11:43 AM
GrantG's Avatar
Hockey Pucks work great for this and other jacking needs (and they're cheap from any sporting goods place).
2022 GT3 Manual, 73 Carrera RS 2.9 Twin-Plug MFI Carbon Fiber Replica
Former: 18 GT3 Manual,16 Cayman GT4, 73 911S, Two 951S's, 996 C2, 993 C2, BMW 635CSi Euro, Ferrari 550 Maranello, 06 Evo IX w/ many mods
Old 07-08-2010, 12:53 PM
KarlCarrera's Avatar
Thanks for the info/pics Bill, and the question Kevin. Got it printed and in the file.
Karl
88 Targa
Old 07-08-2010, 06:18 PM
