Alignment after Corner Balance?
I upgraded my suspension this spring and am now trying to get the alignment and corner balance set. Just after putting everything together, I corner balanced and then aligned. The alignment required big adjustments and resulted in the balance being off. I just rebalanced the car, and the cambers are now off a bit. Are the adjustments small enough that I can I safely reset the cambers without screwing up the balance this time? Here is how I plan to change the cambers:
LF 1.1 -> 1.1
RF 1.5 -> 1.1
LR 2.3 -> 2.5
RR 2.7 -> 2.5
Scott Wilburn
1988 911 Carrera 3.4 L
1998 M3
1984 308 QV
Old 07-15-2010, 08:31 PM
1984-911 M491
Trog's Avatar
It’s an iterative process. Alignment effects height, which effects corner balance, which effects alignment.
Keep at it.
1984-911 TLC......SOLD
Old 07-16-2010, 07:20 AM
