| Registered Join Date: Jun 2004 Location: Los Alamos, NM
				Alignment after Corner Balance?
			I upgraded my suspension this spring and am now trying to get the alignment and corner balance set. Just after putting everything together, I corner balanced and then aligned. The alignment required big adjustments and resulted in the balance being off. I just rebalanced the car, and the cambers are now off a bit. Are the adjustments small enough that I can I safely reset the cambers without screwing up the balance this time? Here is how I plan to change the cambers: LF 1.1 -> 1.1 RF 1.5 -> 1.1 LR 2.3 -> 2.5 RR 2.7 -> 2.5
				__________________ Scott Wilburn 1988 911 Carrera 3.4 L 1998 M3 1984 308 QV | ||
|  07-15-2010, 07:31 PM |
| 1984-911 M491 |
			It’s an iterative process.  Alignment effects height, which effects corner balance, which effects alignment. Keep at it.
				__________________ 1984-911 TLC......SOLD | ||
|  07-16-2010, 06:20 AM |
