Aux. air regulator
Have just bought a new Bosch aux air regulator part no. 0208-140-171 and fitted it to my 73 2.4 CIS engine, which has cured my cold engine idle problem. But when the engine is hot the idle speed stays high. (If I pinch the hose to the aux. air regulator the engine drops to normal idle speed.)
I took it off again and tested it on the bench; the valve seems to close OK (I can't see any daylight through it) but I can still blow air through it when its in the closed position. Does this mean the valve is faulty, or should it still allow air through when in the closed position?
Cheers, Maurice (UK)
Old 06-15-2010, 08:22 AM
Banned
Send a message via AIM to prebordao Send a message via Yahoo to prebordao Send a message via Skype™ to prebordao
It may sound silly, but where did you connect it to ? Did you use the hoses going to the decel valve ?
Old 06-15-2010, 09:36 AM
Send a message via Yahoo to jjrowe
Have you connected the 12v power source? If not it won't heat up and close properly.
Old 06-15-2010, 09:58 AM
aux air reg
Hi Thanks for your quick reply, I connected the air reg in parallel with the decel valve by tee-ing into the hoses going to the decel valve. I can't see the point of fitting the air reg if it still allows air through although it does restrict the air a little when the its closed.
Cheers
Old 06-15-2010, 11:15 AM
Banned
If they're in parallel, maybe air is going through the decel valve when the reg is closed. Try disconnecting (and plugging) the vacuum line going to the decel valve.
I'm interested in your findings cause I've been thinking for a while in doing the same. I even bought an air reg...
Old 06-15-2010, 12:42 PM
air reg
Hi again
I'll give that a try, but in the meantime could you connect your reg to 12v and see if when it closes, you can blow air through it?
Maurice
Old 06-15-2010, 12:55 PM
Banned
I have it in a box, I didn't get to plug it in, but I tried it with 12V and it closes completely.
However, it might naturally allow some air to pass through as it doesn't seem to have any rubber seals that would make it completely airtight. But probably not enough to rise the idle.
Did you buy it new ?
Old 06-15-2010, 04:01 PM
Yes i bought it new last week, going on from what you said about your reg i've decided to take it back to the supplier and get them to change it. I may have been unlucky to have got a faulty unit! I,ll keep you posted on the result.
Old 06-16-2010, 01:55 AM
Banned
I just remembered... did you waited long enough for it to close completely ? I think it takes about 6-8 min
Old 06-16-2010, 03:25 AM
aux air reg
when i had it fitted on the engine i took the car for a run for 30mins and it was up to full temp, thats when i started to investigate why the revs where too high on idle, so pinched the hose to the reg and down came the revs to normal, so it's got to be the reg.
cheers
Old 06-16-2010, 07:43 AM
Banned
Yep, I agree. should be the regulator.
Old 06-16-2010, 08:51 AM
you can make a manual one from a cheap water cooled 924 heater valve.
same overall size, exact same hose connection diameters, and you operate it with a cheap generic choke cable or lawn mower throttle control.
total cost is about $25 and works absolutely perfectly.
Old 06-16-2010, 11:35 AM
aux air reg
Hi JF
Thanks for the tip on going manual, i'm still trying to establish wether the reg i bought should close off completely or it allows a small amount of air to still pass through? if this is the case then the reg i have isn't faulty. If all else fails i'll go with your manual set up.
Cheers
Maurice
Old 06-17-2010, 12:49 AM
There's nothing wrong with it. It is designed to be secured to an aluminum casting on a manifold to absorb heat from a warm engine. There is no place to mount it on your engine.
Old 06-17-2010, 07:23 AM
Banned
Maurice, where did you put the reg ?
I was planning on bolting mine to an aluminum bracket that would sit between the WUR and manifold...
Old 06-17-2010, 07:30 AM
aux air reg
I made a bracket and fitted it to the existing ally mounting which takes the accelerator linkage (just inboard from the wur) so that it would pick up engine heat as well as eletrical heat, there are two threaded holes in the ally mounting bracket which don't appear to be used on my engine.
M
Old 06-17-2010, 02:52 PM
Aux air reg
Hi
Following on from previous posts, i have now abandonded the the idea of using the air reg, and have fitted a 12v solenoid valve in parallel with the de-cel valve which is operated from a switch on the dash, this when open allows just enough extra air to lift the engine revs when cold. Not the solution for the "purists"but my car isn't original anyway (9146 2.4k-jet)
Cheers Maurice
Old 07-12-2010, 03:13 AM
Banned
But why use that instead of the hand throttle ?
My idea for the air reg was to have a completely "auto" system...
Old 07-12-2010, 03:18 AM
Banned
Old 07-12-2010, 03:26 AM
Smile aux air reg
Hi Short answer to your question is i don't have the hand throttle set up anymore, whilst i agree it would be nice to have a fully auto set up it's not as simple as just fitting an air reg which appears to work together with other componants, all getting a bit too involved/expensive!! After all it's only needed for a for a few minutes and works fine.
Cheers
Maurice.
Old 07-14-2010, 03:21 AM
