First Test Drive w/ Fabspeed Premuffler
So after a lot of aggravation removing my old cat, I'm sorry to report I'm less than thrilled with my fabspeed premuffler.
Firstly, it's a bit throaty-er. However it's louder. I was hoping the sound wouldn't really change. Secondly, my car seems to be running hotter. I thought it was supposed to run cooler with a premuffler? Lastly I don't think I saw any performance gain. I figured my stock cat would have been clogged and at least the new premuffler would have brought back some lost hp. Maybe it wasn't as bad as I thought. So, is something wrong. Should I just put my old cat back on???
Matt. 83 911SC 85.5 944 NA - Sold |
Senior Advisor
Porsche does there homework, almost no backpressure from there cat's over there life . Now you need a Dansk sport muffler to go with that bypass.
08 Cayenne Turbo |
i run a dansk premuffler on my 83SC and i had similar results - a little deeper, ever so slightly louder at anything under 2k, after 2k it sounds normal, no seat-of-the-pants dyno improvement. i have not noticed any change in the running temp though.
- He gave his father "the talk" - Once while sailing around the world he found a shortcut - He taught a german shepard how to bark in spanish He is.... nineball. I don't always drive sports cars, but when I do I drive a 1983 911SC Targa. Stay fast my friends. |
You need to change the muffler to get a different tone.
Little to 0 HP gain but the sound will make you giggle like a school girl every time you press the gas pedal. Obviously, many threads have been posted on what muffler is "best". I like my oddball Flo-Pro 1in-1out setup. Check them out and decide for yourself what you like.
1981 911SC ROW SOLD - JULY 2015 Pacific Blue Wayne |
It should at least be cooler on that side of the engine. I once measured the temp at the catalytic converter right after engine shut down and then compared that to the temp with the cat removed and the premuffler in place. There was a significant drop in temperature.
Kurt |
In regards to sound...I already have a GHL 1 in/1 out that I was very happy with sound wise. It seemed to be the perfect volume. Now with the premuffler it's a touch louder than I'd like.
Could something be wrong?
You may need to adjust the fuel/air mixture.
It may be running a bit lean which can cause hotter temps. A gas analyzer is the best way to check.
Is your oxygen sensor hooked up? Did you maybe break a wire on it while you were working in that vicinity?
I've had my O2 sensor disconnected because I'm not sure the lambda system is working properly and I haven't had a chance to go through it yet. So I figured I'd run it disconnected for the time being.
