Which size Smart Racing sway bars?
I am looking into buying a set (front and rear) sway bars from SmartRacing and need advice on the size.
My car is a 1976 911 with a 3.6 engine. I am running 245/35 18 front and 295/30 18 rear tires. I have 22mm front and 30mm rear torsion bars. And Koni adjustable shocks all around.
Currently, I have Carrera sway bars front (22mm) and rear (21mm), and the car has some slight understeering issue, which I plan to solve with the adjustability of the SR sway bars.
thanks in advance,
Mario
'76 911 w/'97 3.6 Euro Vario Engine & Turbo body kit & TPC Supercharger
'15 GT3
Old 07-22-2010, 01:02 PM
gtc gtc is offline
abides.
gtc's Avatar
There is a recommendation chart in the Smart Racing catalog, but if you call them they should be able to tell you which ones to buy.
Graham
1984 Carrera Targa
Old 07-22-2010, 01:26 PM
I have seen it, thanks. I was actually looking feedback from others with a similar setup. They recommend 31r/27f for a track car and 23/23 for stree/track, then they recommend 27/27 for GT (which I am not sure what it means) cars.
My car is used almost exclusively for track (DE events), so I should in pple go for the 31/27 setup, but according to a SR representative this setup is to match 23f/31r torsion bars. As I mentioned in my previous post, my torsion bars are smaller 30/22, so I am not sure which would be the best sway bars for my case.
Any advice will be greatly appreciated.
Mario
'15 GT3
Old 07-22-2010, 02:15 PM
I'm running the Smart setup for street/track (21/29 torsion bars, 23/23 sway bars) and it's great. The risk with running more sway bar with smaller torsion bars is that the sways will do more "work" in the corners relative to the springs. This can cause sheared rear sway bar mounts and damaged sheet metal where the front bar passes through the trunk.
Old 07-22-2010, 02:25 PM
304065's Avatar
31/27
'66 911 #304065 Irischgruen
‘96 993 Carrera 2 Polarsilber
'81 R65
Ex-'88 Carrera (Sold 3/29/02)
Old 07-22-2010, 05:21 PM
PRO Motorsports
Tyson Schmidt's Avatar
I think you meant 31F/27R, not the other way around.
There is plenty of adjustability in these bars, so your slightly different torsion bar sizes is not an issue.
Since you say it's almost exclusively a track car, then definitely go 31F 27R.
'69 911E coupe' RSR clone-in-progress (retired 911-Spec racer)
'72 911T Targa MFI 2.4E spec(Formerly "Scruffy")
2004 GT3
Old 07-22-2010, 06:22 PM
why not 27/27?
Wouldn't 31f/27r make my understeering issue worst?
Mario
'15 GT3
Old 07-22-2010, 07:37 PM
Yes, you are right Tyson. thanks
Mario
'15 GT3
Old 07-22-2010, 07:38 PM
Insert Tag Line HERE.....
rattlsnak's Avatar
31/27
Old 07-22-2010, 07:45 PM
Steve W's Avatar
I have 22/29s as a mixed use car and Rich Walton of Smart Racing strongly recommended 31/27s and they're incredible. It's a huge and completely different level of performance over the standard 22 mm adjustables I had previously. Your car will corner so flat, it will be on three wheels if you transition a driveway at a diagonal. Throttle steer will have a whole new definition. Since yours is a DE track car, it should be no question.
You can soften the bars for a softer ride on the street, or stiffen more for track, but the setting I use works well for both and the ride for street is not bad at all.
Old 07-22-2010, 08:11 PM
Nice thing about the SR sways is you can interchange the bars beteen the front and rear. And, if you need to you can just buy another bar for a fair price.
I am not a suspention expert but I would look to stiffer torsion bars first as this helps sway and dive. Sways should be more for ballance.
Also, I suspect a relitively large sway's makes for a large varation in effective wheel spring rates in bump, sway, and dive -- making it more difficult to find a shock rate to cover all conditions.
It seem that in the case of a torsion bar 911 where the torsion bar rates are limited, larger sway bars seem to be used as a 'spring substuite' on top of a way to ballance the car.
However, I understand it is easyer to just add stiffer sway bars.
A dual use car is a different story.
Old 07-22-2010, 08:55 PM
Max Sluiter
Flieger's Avatar
Yes, it is easier to add anti-sway bars but they do not control dive/squat. You can tune the balance of the suspension's roll stiffness easily, though.
Old 07-22-2010, 08:59 PM
I think I just said that.
Originally Posted by 911st View Post
...I would look to stiffer torsion bars first as this helps sway and dive. Sways should be more for ballance. ...
Old 07-22-2010, 09:37 PM
Max Sluiter
Flieger's Avatar
Sorry, I was just poking fun at your spelling. I agree with the comments.
Old 07-22-2010, 11:59 PM
Question for Steve or others:
I have 22mm Welt sway bar in the front. I was thinking about upgrading to a larger smart bar. Obviously, the bar will be larger which in turn will require a larger hole.
Will I be able to use the three mounting holes I drilled for my Welt bar or will I need new holes?
2011 Cayman Speed Yellow
1988 924S (Sold) 2000 Boxster S (Sold)
2006 Cayman S (Sold) 1990 964 C2 (Sold)
1978 911 SC (Sold)
Old 07-23-2010, 07:31 AM
F,
Got it, not a problem. Totally went over my head.
California school system, a little dyslexia, plus pretty much falling through the cracks while the staff at the orphanage was more concerned with when there next Black Panther meeting was and or participating in the free love movement seems to have contributed to my not quite perfect spelling.
Still, California let me get 3 collage degrees at almost no cost so I am still thankful.
I often forget to run spell check. Just forgot that time.
The best my Friend. Keep up the good work.
Old 07-23-2010, 07:45 AM
Steve W's Avatar
You use the same holes, plus you drill three more equidistant for a total of six.
Old 07-23-2010, 11:02 AM
