Banned
Send a message via AIM to prebordao Send a message via Yahoo to prebordao Send a message via Skype™ to prebordao
Plastic fuel lines: brute force or heat ??
I'm in the process of refitting one of the hard plastic fuel lines into the barbed inlet to the fuel distributor.
What's the recommended way to force it past the first barb ? brute force (not easy) or by heating the line (hair dryer maybe) ?
Old 09-09-2010, 01:28 PM
BoxsterGT's Avatar
Porsche Crest
Brute force, do not use heat.
Len
Old 09-09-2010, 01:41 PM
Banned
oh boy
Old 09-09-2010, 02:16 PM
My other ride is a C-130J
RNajarian's Avatar
I took my line to a local Porsche Shop (TRE). There is a special tool to properly fit the line.
I am told that a diesel mechanic may also be able to fit the line to the barbed end.
I tried to do it myself, heat/pressure/swearing all with no luck
1975 911 Targa S 3.0 2000 911 Carrera Cab 2005 Cayenne Titanium Metallic
2022 Mercedes-Benz E450 Coupé 2020 Mercedes-Benz E350 2006 ACG Hummer
Previously Owned Art from Stuttgart
2000 Boxster -1983 911 SC Cab -1984 944 N/A
Old 09-09-2010, 02:26 PM
there's a special tool that clamps the tube. the tube sticks out the end of the tool about the same length as the barb fitting. let sit in boiling water for a minute and force it over the barb. hold the fitting in a soft jaw vise.
206 637 4071
Old 09-09-2010, 03:11 PM
special tool.
206 637 4071
Old 09-09-2010, 03:16 PM
Banned
I got the point. I'll make something similar out of wood blocks.
Old 09-09-2010, 03:46 PM
wierd, the picture used to be there.
206 637 4071
Old 09-09-2010, 04:59 PM
Dog-faced pony soldier
Porsche-O-Phile's Avatar
Boiling water works well.
Black Cars Matter
Old 09-09-2010, 05:27 PM
Ray_G's Avatar
Pressing nylon fuel lines onto barb fittings
Scroll all the way down on the thread to see the poor boys tooling to press the lines on.
76 911S Targa
An ex F1 driver, and Porsche fanatic (my stepfather) once told me that if you listen very carefully on a quiet night you can actually HEAR Porsches rusting in the garage!
Old 09-09-2010, 06:32 PM
Obsessed
sobamaflyer's Avatar
It never ceases to amaze me how topics pop up here just as I'm dealing with them (so thank you).
I thought I came across something special when I found the Delorean dealer mentioned in the link above, from 2004! A hint, I don't think that dude has any affection for us "Porsche People".....but if I get my new fittings from him by Sat. I'll be happy.
....what is the proper line size and best source for replacement fuel line? Seems our host has what looks like standard rubber lines, not the hard nylon (?) lines currently in place.
'73 Mercedes 450 SL
'75 911 Targa (long gone, sniff..)
http://1975porschetargarebuild.blogspot.com My Targa Rebuild Blog
"Life moves pretty fast, if you don't stop and take a look around once in a while you could miss it!"
Old 09-09-2010, 07:25 PM
Ray_G's Avatar
CIS LINE & FITTINGS
I am not sure of the tubing size, but they sell it. They are not nylon, I believe they are polymide, but anyway this is where to buy it.
76 911S Targa
Old 09-09-2010, 07:43 PM
LOL! I bought out their entire stock of CIS line about two years ago. I have a ton of it in my garage right now if anyone's looking for various diameters/lengths.
It is damn nearly impossible to find this stuff in metric diameters BTW.
Black Cars Matter
Old 09-09-2010, 07:55 PM
Ray_G's Avatar
I have called them recently, they have more. I have not ordered any of it. I am still torn between doing this like it was originally, or going to Goodrich fuel lines. Just can't make my mind up.
76 911S Targa
Old 09-09-2010, 08:08 PM
Banned
Goodrich fuel lines ? are they metal or just different fittings at the ends ? can they be retrofitted ?
Old 09-10-2010, 01:45 AM
Ray_G's Avatar
They are flexible stainless steel lines with a plastic coating on the outside. I think they are teflon on the inside. Anyway they have the same fittings as the original lines. I was quoted 240.00 for a set. I think that included the line from the wur to the distributor and from the fuel filter etc. I have to get with them to make sure that the kit includes them all. I am leaning towards those instead of screwing with making my own. It won't be original, but my car is not so.....
76 911S Targa
Old 09-10-2010, 05:02 AM
Banned
I would like to find a reasonable solution to replace the nylon lines. Specially the ones from WUR to FD and FD to fuel filter...
Old 09-10-2010, 06:02 AM
Ray_G's Avatar
Sent you a PM prebordao. Also, the brand is Goodridge. geez, brainfart here. I think this is the website:
http://www.j2precisionhose.com/estore/product.php?productid=6334&cat=72&page=1
76 911S Targa
Old 09-10-2010, 06:36 AM
T77911S's Avatar
i think i sprayed some valvaline syn lube, maybe dw40 or maybe even skin so soft on one of mine. hey dont laugh, i used it to put the new top seal on my 914, helped it slide on then evaporated. its been a long time now so i cant remember. it helped it slide on. i let it sit until the next day. i tried to twist it the next day and the fitting would not budge. i checked it for leaks over the next few days and wala! years later it is still working fine.
i think i may have used something that i thought would not keep it lubed for any length of time, that was why i let it sit for a day or so.
88 BMW 325is 200K+ SOLD
RACE CAR:: sold
Old 09-10-2010, 09:40 AM
19 years and 17k posts...
azasadny's Avatar
I took mine to a local Parker Fittings shop and they did it for me (no charge)...
Art Zasadny
Learning the bass guitar
www.ford.com
Old 09-10-2010, 11:25 AM
