Dog-faced pony soldier
Porsche-O-Phile's Avatar
BBS wheel question
I pulled apart one of my sets of BBS RS wheels a while back to add deeper dishes. There was some kind of glue/adhesive/sealant stuff between the inner and outer dishes presumably to help make the whole thing airtight. Anyone know what kind of stuff to use for reassembly? Silicone? RTV? Some kind of weird uber-strong industrial stuff? Wurth sealant maybe?
And more importantly where can I find it?
Black Cars Matter
Old 07-27-2010, 08:24 PM
ttweed's Avatar
I have used an "aluminized" silicone adhesive caulk for renewing the seal on multi-part wheels before with good results. Nothing exotic-it's sold in construction and hardware stores for bonding/sealing aluminum gutters and window/door sashes. Since the air pressure in the wheel is tending to drive the bead into the crack, it doesn't have a lot of stress on it, as long as the bolts stay tight. Just make sure the joint is clean and dry before bonding the halves and you shouldn't have any problems.
TT
Tom Tweed
Early S Registry #257
R Gruppe #232
Rennlist Founding Member #990416-1164
Driving Porsches since 1964
Old 07-27-2010, 09:05 PM
Won Won is offline
Won's Avatar
Dow Corning 832 is what we use in the industry.
83 911SC Targa
Everything I say is my personal opinion, and has nothing to do with my team.
Old 07-27-2010, 10:01 PM
Mitch Leland's Avatar
Call BBS - (800) 422-7972
Mitch Leland
"03" 996 C2S-LS3 V8-480 HP
"84" 911 Turbo Look-Sold w/ found memories
Old 07-27-2010, 10:28 PM
Driver
Noah930's Avatar
+1 to ttweed's post. You should be able to find it in any hardware store. I just used the silicone marked for metal-to-metal contact.
1990 Black 964 C2 Targa
Old 07-27-2010, 11:54 PM
wwest's Avatar
There are two types of metal seal rings used in different years of the BBS-RS, one uses a rubber o-ring for the early ones and a "U" shaped rubber seal later. If you buy new seals from BBS you need not worry about additional sealant
Old 07-28-2010, 08:42 AM
