hbf hbf is offline
Tire Advice Needed
The time has come to replace the tires on my '73 911T with Fuchs. Wheel size 185 x 70 x 15. I am being told that this size is NLA.
Is this true? If so, what size is appropriate for these rims?
If not, then any ideas where can I buy the tires?
Comments appreciated.
HBF
Old 07-27-2010, 02:04 PM
Bandwidth AbUser
Jim Richards's Avatar
If you can't find 185/70/15's, you can always use 195/65/15's. Yokohama has this size, if I recall correctly.
Jim R.
Old 07-27-2010, 02:10 PM
racer's Avatar
195/60 can also work.
if you want something "period correct": 185/70VR15 MICHELIN XWX - Michelin - Cars & Trucks - Tire Brands
Past:
2000 Boxster 2.7, 1987 944, 1987 924S
1978 911SC, 1976 914 2.0, 1970 914 w/2056
Old 07-27-2010, 03:54 PM
hbf hbf is offline
Thanks for the responses.
Looks like the 195 x 65 gets me to the same wheel diameter as the original 185 X 70.
The Coker Tire alternative is too expensive for me at $400 a piece.
HBF
Old 07-28-2010, 01:41 PM
Try this calculator:
Tire size calculator
Old 07-28-2010, 04:04 PM
