Help - Electrical problem?
Hi everyone,
I have a small problem that I need some help with.
When I'm driving, all of a sudden, the seat belt light will come on, and my radio will turn off. The car will be driving along fine. Then, after a short while, the seat belt light will go off and the radio will turn back on. At first, I thought it happened only when I drove on bumpy roads, but now, it just happens for no apparent reason. Anyone have any ideas or advice?
Thanks!
1984 Carrera 3.2L Coupe, Guards Red
Old 07-19-2010, 09:56 PM
Do you need either of those in a 911?? ;-) !!
RGruppe #79 '73 Carrera RS spec 2.7 MFI
00 Saab 95 Aero wagon stick
01 Saab 95 Aero wagon auto
03 Boxster
90 Chevy PU Prerunner....1990
Old 07-19-2010, 09:59 PM
Haha, good point. Normally no, but there are times where I want to listen to the game on AM radio.
Old 07-19-2010, 10:00 PM
86 911 Targa's Avatar
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
Originally Posted by laundromatt View Post
Hi everyone,
Thanks!
Do you have a Bentley and a multimeter?
1986 911 Targa.
Per Road and Track magazine:
Only in L.A.:
In the window of a bar in Hermosa Beach, California.
"Happy Hour prices during all car chases."
Old 07-20-2010, 07:52 AM
There have been a couple of posts lately on seat belt lights that come on. I pay attention to them because mine does the same thing. During acceleration, sometimes my seatbelt light comes on. Most say this is due to an over active voltage regulator. I think historically this has been the answer.
I put a volt meter on mine, and didn't notice any change in the voltage when the light came on. That doesn't mean it isn't somehow the voltage regulator, but I am still in the process of trying to find a better answer.
Rex
1975 911s and 2012 Range Rover Sport HSE
1995 BMW R1100RS, 1948 Harley FL
Old 07-20-2010, 07:58 AM
I do not understand the relationship between the combination indicator lamp, and the oil pressure switch.
However, we had the same symptom(s) when the oil pressure switch started to fail.
Replaced the switch, and all is well.
Check for oil around the switch.
Good luck,
Gerry
1986 911 Targa.
Only in L.A.:
Old 07-20-2010, 08:34 AM
I have a multimeter, but no Bentley. Can you explain what I should do with the multimeter?
Old 07-20-2010, 09:25 AM
scotyp's Avatar
Gerry,
I have just looked at this page in the Bentley. My 82' SC is having this issue now. My oil pressure light comes on at the same time as my parking brake light. I have no idea why Porsche decided to gang these two together.
I'm thinking my oil pressure switch is bad and will need to be replaced. Can you do this without a partial engine drop or can you go in from the engine compartment. Looks like a b****h to get to!
Scot
Old 07-20-2010, 10:34 AM
Just to clarify - my oil pressure light does not come on at all. So maybe I have a different problem? Anyone have any advice?
Old 07-20-2010, 11:36 AM
anyone?
Old 07-26-2010, 01:49 PM
The electrical ground is a common electrical point for many loads in the circuit. Locate and ID the ground for the radio and seat belt circuit; you might find the culprit there.
MHO,
Sherwood
Old 07-26-2010, 02:02 PM
dshepp806's Avatar
Agreed,..I'd make sure it's not a pesky ground point FIRST!
Doyle
Recording Engineer, Administrator and Entrepeneur
Designer of Fine Studios, Tube Amplifier Guru
1989 Porsche 911 Carrera Coupe
25th Anniversary Special Edition
Middle Georgia
Old 07-26-2010, 02:42 PM
Monkey+Football
Icemaster's Avatar
Send a message via AIM to Icemaster
Do your headlights change brightness slightly when this happens?
You're more than likely looking at a voltage regulator replacement. There's a very simple test that you can do that involves putting you VM on the battery to see what it reads while the car is running, should be between 13.3 and 13.7 volts IIRC.
I'll be damned if I can find it, but there's a bunch of threads on this forum about troubleshooting and replacing the VR. Start small with the easy tests.
<Insert witty comment>
85 Targa Wong Chip Fabspeed M&K Bilsteins and a bunch of other stuff.
Old 07-26-2010, 05:50 PM
Originally Posted by scotyp View Post
Gerry,
Scot
It is.
You may be in for an engine drop.
On the 3.2 motors no engine drop is required.
You may pm me as required.
Gerry
1986 911 Targa.
Only in L.A.:
Old 07-26-2010, 06:24 PM
MHO,
Sherwood
Thanks for the tip. Can you give me some pointers on how to do this? I don't have a Bentley, so I don't know where/what the circuits are, and where they come into contact with ground. Thanks!
Old 07-28-2010, 02:29 PM
Tools and equipment needed:
- standard hand tools
- something cushioned to lie on
- drop light
- Advil (for your back)
I don't know the Bentley manual to tell you if they ID the locations of the various ground junction points to the chassis. There's one under the dash. I'd look there first since it's closest to the issue area (German ground wires tend to be brown) and it's probably faster than finding some photos/illustrations of the ground connections. It might be loose, dirty and/or corroded. Remove all wire connectors, then clean them to base metal with fine emery or equivalent. Other electrical circuits are normal, yes?
Sherwood
Old 07-28-2010, 03:39 PM
