pokeytom's Avatar
SSI heat exchangers
Please help me with a few questions......Thermal Reactors gone on this 911S! Now, does a 1977 need thick or thin flanges on the heat exchangers? Any peticular year work best with this engine? What about the oxygen sensor fitting? Does it need to be there with the CIS fuel injection?
Thank You
Old 07-27-2010, 03:03 AM
'77 is thin flange and no OX sensor needed. All SSI are the same except for flanges and O2 bung so any set will work as well as any other set as long as they are in good condition. If you have a set with 02 bung find a plug and seal it up.
Lindy
Old 07-27-2010, 07:21 AM
Sorry to disagree with Lindy, The 77 is a thick flange from the thermals with the long, thin in the center 8mm threads long studs. Does not require ox sensor but if the 80 on thick flange heat boxes are available just plug the hole with a used cut off ox sensor.
Bruce
Old 07-27-2010, 07:55 AM
al lkosmal's Avatar
SSI's on 77S
Originally Posted by Flat6pac View Post
Sorry to disagree with Lindy, The 77 is a thick flange from the thermals with the long, thin in the center 8mm threads long studs.......
Bruce
+1 My 77S, formerly with thermal reactors, required thick flange SSI's.
regards,
al
RGruppe #669
http://www.x-faktory.com/
Old 07-27-2010, 08:03 AM
I stand corrected. Sorry for the bad advice.
Lindy
Old 07-27-2010, 12:32 PM
Thank You
Save those thermals along with the rest of the exhaust! They're like gold or Unobtainium now that smog is getting to be an issue in a lot of states.
Cheers,
Joe
Old 07-27-2010, 12:38 PM
pokeytom's Avatar
Thank you everyone! You guys know all the answers.
Tom
Old 07-27-2010, 06:48 PM
