gauge bulb socket replacement
Hello,
After a melt down of my wiring for the dashboard lights I decided to put in the dashlight fuse instalation as described in Dash lighting fuse installation I want to replace all the dashboard light wiring from scratch but have not found out how I can re-use the "bulb sockets (99906320007000)". The wire goes inside but I can not figute out how to get it out and replace it with a new wire. ![]() Thanks for your assistance! Bruno - Bredene - Belgium - 911sc 05/78 |
Weekend Mechanic
Hey Bruno,
Why not just strip the casing and solder onto the existing wires then use shrink tubing to seal it up? That way you don't have to worry about opening and potentially damaging the sockets. J
86 911 Carrera Targa
Thanks for teh feedback. Sounds like a good alternative. I just wonder how they would do this in a porsche garage, there must be a trick?
French Import
They would most likely replace a portion of the wire harness and charge an arm and a leg...
Gilles & Kathy Happiness is not having a Porsche in the garage... Happiness is having a Porsche on the road! ![]() 86 Porsche 911 Cabriolet, 2011 BMW 1200RT, 03 Saab 93 Cabriolet, 06 MB E350 Estate |
