brd brd is offline
brd's Avatar
How can I test a speedo sensor on 915 box?
Hello,
My speedo doesn't work (didn't since I got the car last year - must likely because of a re-wiring botchjob before). The speedo itself is new and I am tracing the wires to check them.
Anyone know how I can check the actual electronic speedo sensor that mounts on the side of the 915 gearbox?
i.e. Ohms across it, etc.
Thanks for your help!
BRD
Old 08-01-2010, 02:33 AM
E Sully's Avatar
Just put the meter set to Ohms across the 2 leads in the tunnel, as you rotate the wheel you will see it pulse.
Ed
1973.5 T
Old 08-01-2010, 05:13 AM
brd brd is offline
brd's Avatar
Ahhh... perfect. Thanks!!
Old 08-01-2010, 05:39 AM
need sensor i have a good used one
Old 08-01-2010, 10:28 AM
brd brd is offline
brd's Avatar
Just checked the sensor... all fine there. Am checking the wiring on the speedo now.
You happen to know which wires go where?
I have two speedos... a 260kph one (I think) and a 300kph one. They have different pins being used on the back.
The 300 one has +, 2 (not used), A, 31b, -
The 260 one has +, 2 , A (not used), 31b, -
I'm guessing the two signal cables go to 2 or A and 31b.... and other two are power and ground?
I am actually not sure which one is the right one... 260 one was in car (it's new), but never worked - which I'd blame on bodgy wiring that I have been fixing these last months.
Thanks for your help!!!
brd.
Old 08-01-2010, 11:40 AM
E Sully's Avatar
Just a hint, but info on the car and engine helps when asking questions.
Here is a pic I found doing a search.
12V power goes to the top+ terminal, ground and one lead of the speed sensor goes to the
bottom - terminal, and the other leg of the speed sensor goes to the
31b terminal.
Ed
1973.5 T
Old 08-01-2010, 12:32 PM
brd brd is offline
brd's Avatar
Your completely right Ed.... Its an 81 SC engine with 915 box in a 1970 911T... and the existing wiring is a repair job... which I tried to do right with the correct colours etc... but prefered to work with the connector references on the back of the speedo. I found that post too with that pic... followed it... found the SC wiring diagram (also here on fabulous Pelican) and saw the little detail that sorted everything: One of the speedo sensor cables has to go to that ground pin on the back of the clock with a spade splitter connector. The second goes to 31b... then add 12v to + pin... and rock n roll!!!
I'll check thats its reading right enough next time out with a TomTom.
Thanks for everyones help... again!
BRD
Old 08-01-2010, 01:09 PM
