Confirm my "Bad Clutch" diagnosis
This morning on my way to work I was cruising about 40, I hit the gas not too hard to accelerate and heard 3 klump klump klump, 15 seconds later the car seemed to not be in gear. I pulled into a parking space, the car seems to go into gear, when I release the clutch I hear a faint grinding/rubbing noise and get no movement. Do you agree that my car is a candidate for a clutch job now?
82 911 SC 3.0, 915 |
ANSWER PRICE LIST (as seen in someone's shop) Answers - - - - - - - - - - - - - - - - $0.75 Answers (requiring thought) - - - - $1.25 Answers (correct) - - - - - - - - - - $12.50 Last edited by Grady Clay; 07-27-2010 at 12:56 PM.. |
Yep. Sounds like an axle. It happened to me racing a Camaro down the highway, just more violent thumps!
RETIRED
Drive side CV unless you have LSD....usually the passenger side. On my SC< I found it easier/cheaper to replace the whole axle. Ask for Eric, PMB Performance: Online Parts Catalog (801) 674-3669
Best to replace both. My other side went inside of 300 miles. |
Here are a couple of pics of the results:
Drivers Side: Passengers Side: ![]() I didn't have a jack large enough to get the huge jack stands I bought underneath the car. I'll have a jack tomorrow. Am I correct in thinking that when the car is in gear on stands that the axles should rotate if the clutch is indeed good? If the axles are rotating, should I just tighten the bolts and torque them properly, or should I remove and rebuild the axles? What should I look for when I do an inspection?
Here's the passenger side picture.
Yikes!
I suspect someone didn’t tighten the CV joint bolts properly. There is also the widely held opinion that the CV joints are under-sized - design flaw. Porsche up-graded the axles to the (earlier) 108 mm CV joints in about ’86. I would remove both axles and stub axles and clean and inspect everything. The threads and mating surfaces are most important. Replace all the bolts and Schnorr washers. This is a good opportunity to replace the boots and grease. When you reinstall, make sure you don’t get grease on the bolt threads or mating surfaces. Most important – re-torque the CV joint bolts after a few hundred miles and periodically after. Read and study the thread linked above. While long, it contains a lot of valuable information and links. Best, Grady
ANSWER PRICE LIST (as seen in someone's shop) Answers - - - - - - - - - - - - - - - - $0.75 Answers (requiring thought) - - - - $1.25 Answers (correct) - - - - - - - - - - $12.50 Last edited by Grady Clay; 07-29-2010 at 01:50 PM.. Reason: spellin |
UnRegistered User
You probably have it licked by getting your CVs bolted up properly. There are a ton of threads on this if you do a search.
Bill K. "I started out with nothin and I still got most of it left...." 83 911 SC Guards Red (now gone) And I sold a bunch of parts I hadn't installed yet. |
Grady,
Thanks for the replies, I'm ordering boots and grease now. Do you agree that this problem is the likely culprit to my klunking and non-movement?
Goldfinger
The klunking and no movement is because the bolts backed out.....it has nothing to do with boots or grease.....although it's never a bad idea to service your CV's. It's obvious from the pics that the bolts backed out so far that they aren't even in the hub anymore....I can't believe that the axle is still in line with the hub.
1984-Carrera (pewter metallic) |
Designer King
Grady,
Would it be a fairly safe assumption that if someone's CVs were replaced in the last 20 years or so, that they would be w/ the 108mm versions? Were the smaller ones discontinued?
Paul Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9 Never leave well enough alone |
The husband of a woman I work with had a similar problem. He thought it was the clutch so he parked it for 5 years!!!!!!
I told them I'd take a look at it. 30 minutes later I tightened the CV bolts and it was fixed. Unfortunately by leaving it parked for 5 years, the CIS system was crap, along with the fuel tank and fuel lines
2014 Cayman S (track rat w/GT4 suspension) 1979 930 (475 rwhp at 0.95 bar) |
WOW,...look at that sheeit!!!!!!!!!!!!!!!! I'll be checking mine THIS weekend.
Best, Doyle
Recording Engineer, Administrator and Entrepeneur Designer of Fine Studios, Tube Amplifier Guru 1989 Porsche 911 Carrera Coupe 25th Anniversary Special Edition Middle Georgia |
Checked out
If you look at your pictures, you can clearly see that the bolts are coming out! The pax side has one visible coming out, the drivers side are all loose. This is not a "likely culprit." This IS the problem. Your driver's side axle is no longer connected. |
Goldfinger
BTW....I love your response. Here's mine..... Go get a damn allen socket set.....tighten it.....and drive off smiling. Then get the grease and the boots and plan a weekend of some serious beer drinking and don't forget the rubber gloves. This job is messy at best.
Checked out
Post #5 says "drivers side" and those are all backed out.
Anyways, I'm with you. The boots all look fine to me, I'd just clean everything up, look at it closely, and if everything checks out I'd just make sure the bolts and bolt holes were cleaned out well with brake cleaner (or whatever), tighten those bad boys down and take off. I would check them every now and then to see how they are going. You could never go wrong with Grady's more thorough suggestion, though. But I'd first try a a "clean and tighten" because they may have backed out because some mechanic simply forgot to torque them down well. |
I had a similar experience (mine came off the tranny) - diagnosed it before I rolled to a stop. It helps to be your own mechanic. If it happens again I will drill and wire those suckers.
75 911S Targa - Mine from 2001 until sold to Germany buyer 10/2016 <ALL DIY> Brakes/Wheels '01, Body/paint/restoration 7/04, Suspension 3/07 Engine rebuild - done 7/08 - added 28 tube cooler and SSIs - running strong. Ducktail painted. 2021 MachE, 2012 Outback, 2019 Crosstrek, 2018 Impreza wagon |
I've made good progress, got the passenger side axle removed and it looks fine, all the mating surfaces are not gouged or scored. All the bolts are likely stretched, they all have flat threads near the tip, is this indicative of damaged threads on the wheel hub as well? 3 bolts are straight with flattened threads, 2 are bent with flattened threads, and one sheared off.
I'm going to remove the sheared off bolt tip with a left hand drill today. How would I judge if the threads on the wheel hub are still good? Can I use transmission side bolts to see if they go in and out easily? I have also cleaned a large amount of grease that came out, should I put some more grease in the wheel end of the axle, it looks a little low. I've ordered new bolts, gaskets and grease, but I couldn't find washers. ![]() ![]() ![]()
Uh oh. Looks like the much-touted schnoor washer "upgrade" failed to keep these bolts from coming lose.
In my humble opinion, re-touring these bolts after driving a while (recommended in the factory manual) and then again every so often (recommended by me) may be more important than adding washers.
1979 911 SC Silver 2002 996 race car 2005 Ford Excursion |
