16 or 17mm dia Front Torsion Bars
I need a pair of 16mm or 17mm diameter front torsion bars.
I think that the 16mm bar was made for an RSR and the 911R used a 17mm dia.
I don't want to try reduce the diameter of stock bars as they are quite difficult to machine and the residual stresses may cause a fatigue problem.
Any ideas?
Old 08-04-2010, 01:31 AM
Ayo Irpin, Ukraine!
70SATMan's Avatar
Any ideas?
Torsion bars or Sway Bars???
19mm was the standard front Torsion bar. I believe the original RSR ran at the most 21mm.
As for sway bars, RSR ran both the 18 and 19mm front sway IIRC
The R ran the front 15 or 16mm sways I believe.
Never heard of 16 or 17mm front Torsions.
Harmlessly passing gas in the grassland away;
Only dimly aware of a certain smell in the air
Old 08-04-2010, 08:41 AM
Administrator
Jack Olsen's Avatar
You are misinformed. The RSR and 911R did not use torsion bars in those sizes.
Old 08-04-2010, 01:14 PM
Torsion Bars
I now realise that I did make a mistake
It was not the RSR that used 16mm dia front torsion bars it was the 911 SC/RS and they were in fact 16.7mm dia
Part Numbers 954.343.101.00 L 954.343.101.00 R
From 911 SC/RS Parts List
It is also true that the 911R did not have 17mm dia bars they were in fact 17.1mm.
Part Numbers 901.343.101.13 L 901.343.102.13 R
From Catalogue E-133 November 1967
I will try to be more accurate in future.
All of these parts are, of course, NLA I was just hoping to find some old stock.
I guess I will have to gun drill some hollow bars to give the equivalent stiffness.
Old 08-05-2010, 12:53 AM
Max Sluiter
Flieger's Avatar
Wow, why so soft? Did the Larousse TdF 911R lightweight also use such soft bars? I am surprised that the SCRS used even smaller bars.
Old 08-05-2010, 10:52 AM
