-   -   Time to dig in...softie conversion (http://forums.pelicanparts.com/porsche-911-technical-forum/557256-time-dig-softie-conversion.html)
speedo 06-22-2013 06:54 PM
Rear shelf and crescent
I think this is the hardest part of the interior. The crescent needed so much rehab, and the shelf needed to be recreated. I rehabed the crescent back to where it could be used.
http://forums.pelicanparts.com/uploa...1371951544.jpg
The reinstalled vinyl that trims out the rear shelf
http://forums.pelicanparts.com/uploa...1371951665.jpg
Worked out well...now the attention goes to the shelf itself.
http://forums.pelicanparts.com/uploa...1371951746.jpg
I need two hinged areas, the first is from the shelf to the seat back, and the second is from the seatback to the attach points at the seat back base
So I decided to create a flexible hinge and use remnants from old bike inner tubes http://forums.pelicanparts.com/uploa...1371952031.jpg
I will score the cardboard with a razor to facilitate the hinge, then add a rubber backing to allow the hinge to move
http://forums.pelicanparts.com/uploa...1371952156.jpg
http://forums.pelicanparts.com/uploa...1371952194.jpg
Ok, that worked well...now I just need to get the shelf to flex to prepare the shelf for recovering...so far so good
http://forums.pelicanparts.com/uploa...1371952372.jpg
http://forums.pelicanparts.com/uploa...1371952414.jpg
Closer to installing the softie....
merbesfield 06-22-2013 07:01 PM
Looking good. Very creative.
speedo 06-23-2013 05:14 PM
shelf paper...sort of
I need to get the vinyl on the shelf but first the attachment of the crescent to the shelf is critical. There is no room for modification or adjustment once installed. Lots of assembly to fit , disassembly and trim ...and repeat, and repeat.
These are the pins that puncture and are secured to the shelf and then go through the crescent and are secured to the crescent with speednuts. They look like short roofing nails. In fact I needed to replace a couple and had to clip a few roofing nails.
http://forums.pelicanparts.com/uploa...1372031807.jpg
Everyting has to line up perfectly and the pins are attached before the shelf get it's foam
http://forums.pelicanparts.com/uploa...1372031834.jpg
Lining things up...first set of speednuts securing the pins to the shelf
http://forums.pelicanparts.com/uploa...1372031863.jpg
This tab secures the bottom of the center of the shelf/seat back to the center hoop... shown next at the bottom of the horizontal
http://forums.pelicanparts.com/uploa...1372031883.jpg
http://forums.pelicanparts.com/uploa...1372031906.jpg
And I cannot forget to glue the foam seat buckets in ...before I go any further
http://forums.pelicanparts.com/uploa...1372031925.jpg
They look like they are covered in rust, but the color is just the old factory glue that pulled up with the seats.
speedo 06-23-2013 05:39 PM
Ready for the shelf
All sewed up, but not trimmed
http://forums.pelicanparts.com/uploa...1372032965.jpg
Foam trimmed and glued
http://forums.pelicanparts.com/uploa...1372033010.jpg
http://forums.pelicanparts.com/uploa...1372033029.jpg
Size, trim, stretch and glue
http://forums.pelicanparts.com/uploa...1372033093.jpg
http://forums.pelicanparts.com/uploa...1372033137.jpg
And voila...new shelf with crescent attached
http://forums.pelicanparts.com/uploa...1372033210.jpg
I am pleased...but it was a lot of work. Upholstery shops...the good ones are worth every penny. You just don't realize how much prep goes into the work before the install. Truly an art, learned through experience...not a science
http://forums.pelicanparts.com/uploa...1372033432.jpg
And temporarily installed for fitment.
http://forums.pelicanparts.com/uploa...1372033887.jpg
So from this
http://forums.pelicanparts.com/uploa...1372033946.jpg
To this
http://forums.pelicanparts.com/uploa...1372034273.jpg
Then it comes back out for carpet installation. After the carpet, the shelf goes in for good, the softie gets installed, then the headliner, then side covers and side trim. Finally the targa cover, rear and front targa seals and then door seals. Yeah...this stuff just goes together by itself.
vintagecarlover 06-24-2013 04:57 AM
Do u sleep? Lars, u are amazing...omg
lateapex911 06-24-2013 09:34 PM
Glad I have a coupe!
Great work!
67targa 06-24-2013 11:00 PM
Lars that shelf looks very professional! Clever use of a bicycle tube. I used the same size tube for the portion of the wiring harness from the firewall to the engine bay, it looks like the original.
Can you tell me where you got the card board material for the shelf?
Great work!
bigel 06-25-2013 03:18 AM
Wow...:eek:
speedo 07-03-2013 05:46 PM
Incoming....
I am dealing with carpet issues...more on that later. This long weekend needs to be productive. I am going to go ahead and mount the front fenders and lights etc. Fortunately I set aside the front wiring harnesses...and remembered where I set them.
http://forums.pelicanparts.com/uploa...1372897468.jpg
Kind of a bugger to get them installed correctly, but when they are seated, they aren't going anywhere
http://forums.pelicanparts.com/uploa...1372897536.jpg
And it is way easier to do this without the fenders being installed (or I should say almost impossible to do it after the fenders are installed)
http://forums.pelicanparts.com/uploa...1372897623.jpg
Fender sealing tape in place
http://forums.pelicanparts.com/uploa...1372897662.jpg
A lack of the correct washers delays the fender install for a day...but I dreaded replacing the old heater ducting that exit the longitudinals and passes up through the firewall to the heater blower . New ducting...and wasn't as bad as I thought
http://forums.pelicanparts.com/uploa...1372897790.jpg
http://forums.pelicanparts.com/uploa...1372897820.jpg
My carpet set was worn in the rear seat area, and the replacement set I bought a year ago was in good condition...but when I did a thorough itemization of the parts...realized that it was missing some of the same rear parts that were bad on my original set.
http://forums.pelicanparts.com/uploa...1372897996.jpg
Too late to go back to the seller and complain. My fault on this one. I'll add the original carpet to this replacement set and sell them as-is.
I can however work on the rear seat backs while waiting for the new carpet set to arrive.
These are in decent shape...vinyl is good (could be refreshed), but there is some corrosion on the attachment brackets.
I will recarpet the seat backs with fresh carpet, but these come off first
http://forums.pelicanparts.com/uploa...1372898504.jpg
The leather straps with snaps were so brittle they just crumbled in my hands...so I guess I will get to replace those while I am at it...grunt.
merbesfield 07-03-2013 07:56 PM
Looking good Lars. I was going to work on my 66 this we, but got lazy and decided to skip town and head to the lake instead.
speedo 07-04-2013 11:50 AM
rear seats almost...
Bummer...Mcguckins Hardware (best hardware store in the world) is closed today and I need some metric bits. I guess I will shuffle over to HD and see if they can help me out. I want to get this guy attached today
http://forums.pelicanparts.com/uploa...1372961841.jpg
http://forums.pelicanparts.com/uploa...1372961865.jpg
Back to the seat(s) backs. Clean them up and repaint the brackets
http://forums.pelicanparts.com/uploa...1372962141.jpg
http://forums.pelicanparts.com/uploa...1372962192.jpg
Much cleaner
http://forums.pelicanparts.com/uploa...1372962244.jpg
I need to dress the vinyl
http://forums.pelicanparts.com/uploa...1372962316.jpg
Came out nice. Not new...but definitely newer, or more newish, at least better
http://forums.pelicanparts.com/uploa...1372962410.jpg
This is all I can do till I get my new carpet set...and finish these up by attaching the rear carpet backs.
Fenders Ho!
merbesfield 07-04-2013 06:53 PM
HD sucks. I don't even waste time looking there anymore. Hope you got luckey. Might find some sheet metal screws at NAPA.
speedo 07-04-2013 07:10 PM
Ok, I need some sense of accomplishment...something big
And the fenders will do. First things first. I had a rusted out bolt on the right top door hinge that needed to be drilled out and re-tapped. Once that was done, I needed to install the strikers. I had to source later/newer strikers as mine were a bit worn
http://forums.pelicanparts.com/uploa...1372987778.jpg
I am always hesitant installing strikers when the lockpost has been replaced. A lot can go wrong and although you have "several degrees of adjustment" things can get ugly real quick. Fortunately my original measurements were decent and the strikers needed little adjustment to be dead on.
http://forums.pelicanparts.com/uploa...1372989221.jpg
Once both strikers were adjusted to get the rear of the door gaps correct, time to move to the fenders...left side
http://forums.pelicanparts.com/uploa...1372989430.jpg
And right side ...hey it was raining when I brought the fender down from above. We are experiencing a pleasurable but rare afternoon monsoon season in the front range of Colorado...a bit of artistic license
http://forums.pelicanparts.com/uploa...1372989588.jpg
As the song says ..."both sides now"
http://forums.pelicanparts.com/uploa...1372989642.jpg
Need to install the snakes...front hood gaskets
http://forums.pelicanparts.com/uploa...1372989681.jpg
So I can install the hood...damn, this has been a long haul to make the front of the car look like the front of a car.
http://forums.pelicanparts.com/uploa...1372989797.jpg
http://forums.pelicanparts.com/uploa...1372989860.jpg
I need to deal with hooking up the various wiring before getting to excited about installing headlights and turn signals...and then the front bumper. Hey, it's the first day of a four day weekend...whoohoo
http://forums.pelicanparts.com/support/smileys/clap.gif
Speedo
jakz 07-04-2013 11:53 PM
Looking good congrats! :eek:http://forums.pelicanparts.com/suppo...s/beerchug.gif
merbesfield 07-05-2013 08:33 AM
I admire your energy level and continued commitment.
Edit, as I sit on my ass doing nothing......
DGriz 07-05-2013 09:03 AM
Nice work. I'm just down the way in Denver, so I hope to see the car in person one day.
lateapex911 07-05-2013 02:30 PM
Ha! Good point. Ok, going to go work on the yard. Yea, it's not the 911, but it moves the 911 up the list a teeny bit if i get other things done.
speedo 07-05-2013 05:21 PM
Those dang seat back snaps...or, "while I'm waiting for my new carpet set to arrive"
Ashes to ashes...these turned to dust
http://forums.pelicanparts.com/uploa...1373068973.jpg
I guess it makes sense as the rear shelf is typically an oven in a coupe. In a targa , we have more glass...ie the oven is bigger. Probably why my rear shelf and crescent were trash. Nothing left to this leather strap. I was thinking when I felt the leather initially that some oil might save it. It shattered before I had a chance. Forensic study...like piecing back together dinosaur bones
http://forums.pelicanparts.com/uploa...1373069340.jpg
Two cobblers nails secure the straps on each seat back
http://forums.pelicanparts.com/uploa...1373069471.jpg
I have some scraps of thick leather that should work
http://forums.pelicanparts.com/uploa...1373069404.jpg
I had the tool that allows me to set the two halves of the snap
http://forums.pelicanparts.com/uploa...1373069550.jpg
Test fit on the other side
http://forums.pelicanparts.com/uploa...1373069598.jpg
I may need to move these when I adhesive the new seat backs with carpet, but overall that was easy...at least with the seats on a work bench, not in the back of the car.
So I was asked for the choke size for some webers that I sold recently and I couldn't tell if the close-up picture was going to be in focus...guess this is what you see right after you get sucked into the air horn of a weber at 7000 rpm :eek:
http://forums.pelicanparts.com/uploa...1373069867.jpg
BTW...the chokes are 32s. :D
speedo 08-03-2013 05:34 PM
Got the carpet, but don't feel like a carpet layer...today
Also received the parts I needed to install the fuel filler neck. May as well knock that out and finish up the fuel filler "apartment".
http://forums.pelicanparts.com/uploa...1375575779.jpg
Of course when you are "in the moment" things go together as planned. Get out of the moment and you do the same thing three times to get it right. I installed the rubber cuff, and the filler neck with the hard wire strip that holds the cuff in place. Whoops, forgot the foam donut that seats the steel filler neck against the inner fender wall. Ok, remove, slide the donut over the filler neck and re-install. Crap, the support that holds the gas pump nozzle firmly in the filler neck was cracked on one side. Hmmm, blow it off or fix it. :rolleyes: Fix it...so I dis-assembled everything again and welded both sides of the support. This is before using the Dremel to treat the welds.
http://forums.pelicanparts.com/uploa...1375575888.jpg
Re-install a third time (remember the in the moment vs out of the moment thing...) and tighten everything back up.
http://forums.pelicanparts.com/uploa...1375576251.jpg
http://forums.pelicanparts.com/uploa...1375576274.jpg
Much better. Now I don't need to worry about the gas pump support breaking loose and sliding down into the gas tank...that would suck. Freshly plated tank cap with a new cork gasket is happy.
speedo 08-03-2013 05:56 PM
Expansion tank is next...
But it has seen better days.
http://forums.pelicanparts.com/uploa...1375577296.jpg
Time for a swim, I can't install it looking like this. In you go...
http://forums.pelicanparts.com/uploa...1375577373.jpg
After some elbow grease, the road crap came loose
http://forums.pelicanparts.com/uploa...1375577414.jpg
Restored strap
http://forums.pelicanparts.com/uploa...1375577459.jpg
Installed and plumbed with fresh tubing and clamps
http://forums.pelicanparts.com/uploa...1375577544.jpg
Filler drain tube gets cleaned up and installed in the new rubber filler cuff.
http://forums.pelicanparts.com/uploa...1375577592.jpg
I think I am done with the fuel system at least on the front of the car for now.
I deserve some bling...so bling is next :D
